i was wondering this because i saw a picture of a 3800 with a knock sensor on either side and i wasn't sure if my motor would have 2 or not ? its a series 2 97 gtp
Should have one on the front and one on the back. Middle of block pretty much...
Front one is easy to see and get to. laying under the car, it's above the starter toward the compressor... Rear one is tighter to get to. gotta slide up under a bit more and look up between the part of your trans that runs along your motor and your motor. Should look like the sensor in the front.
