Thread: hot do i line up a vs cam with a stock timing chain gear?
Results 1 to 8 of 8
  1. #1 hot do i line up a vs cam with a stock timing chain gear?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    i was looking at my original cam and noticed that it had a notch in it for the timing chain. then i looked at my vs cam and noticed that there is no notch????
    is it supposed to be like this and also how am i supposed to put the timing chain on ?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: hot do i line up a vs cam with a stock timing chain gear?
    Pull the key way out of one cam put it in the other
  3. #3 Re: hot do i line up a vs cam with a stock timing chain gear?
    May 2008
    Schuyler, NE
    ^^That
  4. #4 Re: hot do i line up a vs cam with a stock timing chain gear?
    Sep 2011
    palm harbor florida
    how do i do that without breaking it or damaging it
  5. #5 Re: hot do i line up a vs cam with a stock timing chain gear?
    May 2008
    Schuyler, NE
    I always pop it out of the old cam with a screwdriver, then place the key in the new keyway on the new cam. Stick the nose of the cam on a piece of wood and give it a couple gentle taps with a hammer until it's in place.
  6. #6 Re: hot do i line up a vs cam with a stock timing chain gear?
    pull it out, its a 1/2 moon shape on the inside, wiggle and pull it out.
    if its stuck in the cam gear, punch it out with a screw driver.
  7. #7 Re: hot do i line up a vs cam with a stock timing chain gear?
    May 2008
    Schuyler, NE
    It's not half moon key.
  8. #8 Re: hot do i line up a vs cam with a stock timing chain gear?
    Sep 2011
    palm harbor florida
    alright ill give it a try. thanks guys
  1. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  2. boost gauge for stock timing chain
    By Dam20735 in forum Wanted To Trade
    Last Post: 05-22-2013, 05:52 PM
  3. Replies: 5
    Last Post: 02-12-2013, 12:58 AM
  4. Rollin the dice... 130 PAC springs on a stock timing chain
    By darkhorizon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2012, 04:09 PM
  5. 3.1 timing chain
    By bybeecl in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-01-2011, 11:56 AM
