Thread: Rollin the dice... 130 PAC springs on a stock timing chain
Results 1 to 5 of 5
  1. #1 Rollin the dice... 130 PAC springs on a stock timing chain
    Feb 2009
    flintnasty MI
    Should I start a pool? Squares $1 each?
    They are mounted on a stock cam/1.9 zzp modded rocker... 20+psi of turbo, and going to touch 7k rpms.
    Ohio
    Running hard errday?
  3. #3 Re: Rollin the dice... 130 PAC springs on a stock timing chain
    how bad could it really be? so what if the tensioner breaks...you'll know it.
  4. #4 Re: Rollin the dice... 130 PAC springs on a stock timing chain
    I ran 130#'s on single JP for probably 10K miles with S1X and 1.8 rockers. But I wasn't spinning to 7k
  5. #5 Re: Rollin the dice... 130 PAC springs on a stock timing chain
    Mullet Member Wotgtp's Avatar
    Connecticut
    3800's are never a sure bet.
  1. 3.1 timing chain
    By bybeecl in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-01-2011, 11:56 AM
  2. timing chain
    By pure in forum General Tech Discussion
    Last Post: 08-16-2009, 02:00 PM
  3. Which timing chain to get.
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 09:01 AM
