Thread: Curious sount/Interesting temp fluctuations
Results 1 to 9 of 9
  1. #1 Curious sount/Interesting temp fluctuations
    Apr 2011
    Ohio
    My brother has a 2002 GTP that's had a hard life. It's clear to us now that the thing got in a wreck at some point before we owned it, and we have to pump money into it all the time. Lo and behold . . . we're having another problem with it. Driving along (60 mpg, cruise on) the temp will jump from regular running temp (~95) up to about 240, stay there for a few minutes, then come back down. It does this in a fairly regular and cyclical fashion. While I was away at school, he also had some A/C work done--I wish I'd have known about the A/C problems before he had it "fixed"--my newbie diagnosis is LIM gaskets and coolant elbows (I have a 2002 GP SE 3100 that had the same symptoms).
    Interestingly enough, at about the same time he had the A/C work done the car started making a most interesting noise. The car sounds like s#*t when you start it, almost like a lawnmower. There's also a clicking sound coming from somewhere in the engine compartment that sounds like someone stuck a baseball card in the spokes of a bicycle. A friend of his told him the sound could be caused by the hose connecting the engine block to the radiator collapsing because of a blockage (sounds suspicious to me). Any thoughts on either problem? Thanks.
  2. #2 Re: Curious sount/Interesting temp fluctuations
    sound go away when the ac is on?
  3. #3 Re: Curious sount/Interesting temp fluctuations
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    coupler in the sc
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  4. #4 Re: Curious sount/Interesting temp fluctuations
    Apr 2011
    Ohio
    The sound is persistent whether the A/C is on or off, as is the temp fluctuation. And the sound is most noticeable under acceleration.
  5. #5 Re: Curious sount/Interesting temp fluctuations
    Johnstown, NY
    Take the belt off of the supercharger and start it up. If the rattling sound goes away its the supercharger coupler. $50 fix roughly. It definitely is not a blocked radiator hose.
    For temp fluctuations, is the thermostat still good? could be sticking.
    98 Red Coupe Grand Prix GTP : 180* T-stat, U-Bend delete, NGK TR55's, SLP Catback
    My Ride: http://www.grandprixforums.net/jevik...upe-73301.html
    A must read for modding: http://www.grandprixforums.net/safel...0-a-67580.html
  6. #6 Re: Curious sount/Interesting temp fluctuations
    This fluctuation in temp. Sounds like you'd be sitting still when this is happening or in traffic? Does it do this travelling down the highway?
  7. #7 Re: Curious sount/Interesting temp fluctuations
    Apr 2011
    Ohio
    It does it even when just cruising down the highway. But it gets worse in traffic--worried about it going into overheat mode.
  8. #8 Re: Curious sount/Interesting temp fluctuations
    Pennsylvania
    Is the coolant full and healthy?
  9. #9 Re: Curious sount/Interesting temp fluctuations
    Apr 2011
    Ohio
    It gets along fine after I dump a bunch of coolant into it, but soon after it's back to square 1.
  1. Replaced temp sensor, now temp gauge stays pegged high...
    By DarkLord in forum General Grand Prix Discussion
    Last Post: 04-10-2013, 06:53 AM
  2. Coolent temp Goes to regular temp and drops down?
    By Lukesgrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2012, 08:11 AM
  3. RPM fluctuations
    By GeeXPee in forum General Tech Discussion
    Last Post: 04-02-2011, 04:18 PM
  4. 100 RPM Fluctuations
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-16-2010, 03:25 PM
  5. voltage fluctuations DIC
    By ghostgt in forum General Tech Discussion
    Last Post: 10-31-2008, 10:15 PM
