Thread: Can I re-use the three torque convertor bolts?
Results 1 to 8 of 8
  1. #1 Can I re-use the three torque convertor bolts?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    I am just about done with our motor build and install. I bought ARP bolts for the flex plate but forgot to get the three larger ones for the torque convertor. The old bolts look to be in good shape but I don't know about re-using them??? Are these bolts safe to re-use or should I get new ones? Seems like a lot of power to be transferred through just three bolts to the trans... Keep in mind the motor build should have a little over 300 hp and we have plans for more mods in the future. Experienced replies will be much appreciated.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  2. #2 Re: Can I re-use the three torque convertor bolts?
    They will be fine.
  3. #3 Re: Can I re-use the three torque convertor bolts?
    Washington Michigan
    red lock tight?
  4. #4 Re: Can I re-use the three torque convertor bolts?
    Florida
    No need. Toss some blue on there if you want. Red is overkill.
  5. #5 Re: Can I re-use the three torque convertor bolts?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I suggest some sort of locktite. My first swap I didn't use any AND used and impact to tighten them up. later down the road I heard something rattling, come to find out they backed out some. No biggie, easy fix but could have been prevented.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  6. #6 Re: Can I re-use the three torque convertor bolts?
    I reuse and impact all the time. Multiple times on the same bolts. Never had one loosen and back out.
    I'm thinking db might need to upgrade his impact or have it rebuilt..lol
  7. #7 Re: Can I re-use the three torque convertor bolts?
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    I've had mine in and out 5 times in three different torque converters no loctite. you'll be fine.
    97 Bonneville SE Not so much a 97 anymore
  8. #8 Re: Can I re-use the three torque convertor bolts?
    Washington Michigan
    Thanks guys! I've got just a couple issues to fix and the car will be running soon.
  1. L32 rod bolts torque settings?
    By IBLOWN in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2011, 04:23 PM
  2. Torque Convertor Messing up.
    By 1997GSX in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-08-2010, 09:58 PM
