Thread: 97 supercharger vac lines vs 98 supercharger vac lines ? ned help i think i goofed up
Results 1 to 6 of 6
  1. #1 97 supercharger vac lines vs 98 supercharger vac lines ? ned help i think i goofed up
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    OK so i found out that my original supercharger was no good and the case was torn up... so i bought a new supercharger not thinking about the vacuum lines. i just got the supercharger in the mail today and there a problem.
    original supercharger...
    new supercharger
    now there is no hole for that tube thing... my question is can i change the vacuum system in my car to the newer vacuum line setup or do i have to drill into the case for that thing to work?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: 97 supercharger vac lines vs 98 supercharger vac lines ? ned help i think i goofe
    Use newer setup, it's quicker, easier and you can still buy it at the dealer if you choose to go that route
  3. #3 Re: 97 supercharger vac lines vs 98 supercharger vac lines ? ned help i think i goofe
    Texas
    You can cape off the vac lines going into the case on the 97 and just T off for your FPR
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: 97 supercharger vac lines vs 98 supercharger vac lines ? ned help i think i goofe
    Sep 2011
    palm harbor florida
    the newer style vacuum line setup?
  5. #5 Re: 97 supercharger vac lines vs 98 supercharger vac lines ? ned help i think i goofe
    the vac tree on top of the new sc looks to be on backwards. the fat tube should face the rear it goes to the brake booster.
    heres a 98 vac diagram. not much to it, 5 bucks in T's and new vac lines from the parts store.
  6. #6 Re: 97 supercharger vac lines vs 98 supercharger vac lines ? ned help i think i goofe
    Sep 2011
    palm harbor florida
    alright thanks alot
  1. '97 GTP to '98 GTP drivetrain swap: Supercharger vac lines and misc. ?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2013, 05:36 AM
  2. Pre-bent Brake Lines vs Bending Custom Lines
    By Elite6 in forum General Grand Prix Discussion
    Last Post: 08-31-2012, 07:26 AM
  3. Supercharger bearings shot!:o no more supercharger?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2011, 02:27 PM
  4. Supercharger coupling OR Supercharger belt tensioner?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 07-23-2010, 11:56 AM
  5. Will a 2001 Bonneville supercharger work on a 97 gtp?supercharger swap
    By Bunique7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2010, 08:39 PM
