Thread: How to remove stock fiber exhaust gasket behind cat???
Results 1 to 3 of 3
  1. #1 How to remove stock fiber exhaust gasket behind cat???
    GTP Level Member tms8582's Avatar
    Washington Michigan
    I'm just finishing up a motor install with headers and high flow cat. I notice there is a fiber gasket (i think) on the cat back exhaust flange and it has a chip missing on the side. The exhaust didn't leak with the stock pipes and factory cat but I know it will leak if I install over this gasket. It must of pulled apart removing the stock parts.... I tried removing the gasket with a screw driver but it's difficult on my back and with a bum left shoulder. Is there any tricks for removing this gasket???
    Thanks guys,
    Tim
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  2. #2 Re: How to remove stock fiber exhaust gasket behind cat???
    Grinder, wire wheel.
    If you could get it in there, it will just start chewing it up and fall off.
  3. #3 Re: How to remove stock fiber exhaust gasket behind cat???
    Washington Michigan
    Thanks for the tip! I just got a grinder that I used to fix a crack in my basement wall.
  1. How to remove stuck gasket from throttle body?
    By RideWithPride in forum General Tech Discussion
    Last Post: 07-30-2012, 05:27 PM
  2. How can I remove the stock radio from my 98 GTP?
    By vanels in forum Audio, Security & Visual Electronics
    Last Post: 10-02-2010, 08:49 AM
  3. how to remove stock stereo
    By izup69 in forum 04+ Specifics
    Last Post: 08-18-2010, 04:45 PM
  4. how do you remove the stock muffler
    By mezzoni in forum General Tech Discussion
    Last Post: 07-22-2010, 12:25 PM
