Thread: Has anyone ever used the ARP main studs or Main Cross Bolts?
Results 1 to 3 of 3
  1. #1 Has anyone ever used the ARP main studs or Main Cross Bolts?
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    After having my 300 mile miracle and my new bottom end spinning a main I am replacing rod and main bearings with clevites again but wanted better bolts than what GM can provide if they exist.
    Cross bolts: INTENSE-Racing.com: ARP Main Cross Bolts for 3800 Engine
    Main studs: INTENSE-Racing.com: ARP Main Stud Kit
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Has anyone ever used the ARP main studs or Main Cross Bolts?
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    So it was a main that you spun, ouch. Was there any machine or polish work done on the crank b4 it spun?
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  3. #3 Re: Has anyone ever used the ARP main studs or Main Cross Bolts?
    Aug 2011
    Millbury, OH
    I have them both in my current built car. I had the machine shop that punched out my motor put them in.
    Sent from my iPad using Tapatalk HD
    2000 GTP coupe, Stattama Turbo Setup, A/A intercooled, custom cam, Tischler heads, 3250 stall, Zzp trans, 1" GMR chain, 65# injectors MDP hood, MSP exhaust, and much more.
  1. Can I reuse the rod and main bolts
    By Bob V in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2013, 11:59 AM
  2. Crankshaft Main Cap Cross Bolts
    By NHRA21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2011, 11:02 AM
  3. main cap and rod bolts
    By chev1988rolet in forum General Tech Discussion
    Last Post: 07-30-2010, 09:39 AM
  4. main cap and rod bolts
    By chev1988rolet in forum Off Topic Discussion
    Last Post: 07-30-2010, 01:46 AM
