Thread: will i have problems with a vs cam if idont have a tune?
Results 1 to 20 of 23
  1. #1 will i have problems with a vs cam if idont have a tune?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    Im in the middle of rebuilding my motor.Iive got a vs cam 90# springs seals and retainers on the way. im also running headers. My quiestion is if i will have problems without a tune... and im thinking about getting a pre tuned pcm from overkill or something.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: will i have problems with a vs cam if idont have a tune?
    Canned tunes suck.
    Don't build a motor and not get it tuned...that's just silly.
    But will it run? Yeah.
  3. #3 Re: will i have problems with a vs cam if idont have a tune?
    Feb 2009
    flintnasty MI
    will work just fine.
    I barely tune even the biggest cam cars.. There is very little if any power availibile tuning over stock settings in most cases. Biggest concerns are idle speed/fan temps/etc... not fueling/timing.
  4. #4 Re: will i have problems with a vs cam if idont have a tune?
    Does VS need P0300 removed like the others?
  5. #5 Re: will i have problems with a vs cam if idont have a tune?
    Most of the time it won't trip it because it's such a small lift based cam.
  6. #6 Re: will i have problems with a vs cam if idont have a tune?
    Ohio
    It tripped on my buddies comp g... So it's a maybe. Guess it depends on your mounts to.
  7. #7 Re: will i have problems with a vs cam if idont have a tune?
    Sep 2011
    palm harbor florida
    well i basicly just need to have it run good until i can getr it tuned. i also have to break it in so ive got a little bit of time.
  8. #8 Re: will i have problems with a vs cam if idont have a tune?
    there is no break in time for a cam. drive it like you stole it.
    back in the day you had to, but with roller lifters, those days are over.
  9. #9 Re: will i have problems with a vs cam if idont have a tune?
    If P0300 sets on you, it'll limit things and screw with how it runs.
  10. #10 Re: will i have problems with a vs cam if idont have a tune?
    Sep 2011
    palm harbor florida
    I am rebuilding my entire motor... not just putting in a cam.
  11. #11 Re: will i have problems with a vs cam if idont have a tune?
    Sep 2011
    palm harbor florida
    whats the p0300 code?
  12. #12 Re: will i have problems with a vs cam if idont have a tune?
    Random multiple misfires.
  13. #13 Re: will i have problems with a vs cam if idont have a tune?
    Quote Originally Posted by Doug 97 gtp View Post
    ill re phrase that for you, there is no real break in run time for a engine either, never has been. the cam you used to break in, nothing else.
    mains and rod bearings have zero break in time, they are what they are.
    the rings need to set, and beating on it sets the rings best. so its go or blow. either you built it right or not. no amount of babying the engine will save it or kill it.
  14. #14 Re: will i have problems with a vs cam if idont have a tune?
    Sep 2011
    palm harbor florida
    well im not going to beat the **** out of it right off the bat the gaskets need to seal pproperly and ill probably have a bunch of minor thing to fix or change. but i definetly plan on getting a street tune for a place called tampabaytune. its 300 for a street tune and 500 for a dyno tune
  15. #15 Re: will i have problems with a vs cam if idont have a tune?
    whos telling you all this stuff?
    gasket are set when you bolt them down, ill say it again, the only thing is the rings need to be seated in the cylinders, it has been said, driving it hard right out of the box seats the rings best. the bearings, lower end, cam, are all set and ready to go, if they were to break in, they would also wear out. and im not talking rev limiter burn outs. some firm driving, spirited if you will.
    this is where the term, its gonna "go or blow" comes from. you either built it right, or not. see what im saying.
    if you hear a noise right a way, turn it off, start digging for what you messed up. if you hear nothing bad, and it sounds good, drive it.
  16. #16 Re: will i have problems with a vs cam if idont have a tune?
    Sep 2011
    palm harbor florida
    thats what im talking about. hopefully i dont hear any noises but if i do i have to change something or fix something. hopefully not though
  17. #17 Re: will i have problems with a vs cam if idont have a tune?
    Florida
    Im not sure exactly where you are at but im in the daytona area and i have tuned VS cams before. If your interested PM me and we can figure something out.
  18. #18 Re: will i have problems with a vs cam if idont have a tune?
    Sep 2011
    palm harbor florida
    what did you use to tune it ?
  19. #19 Re: will i have problems with a vs cam if idont have a tune?
    Florida
    I have a dhp powertuner.
  20. #20 Re: will i have problems with a vs cam if idont have a tune?
    Sep 2011
    palm harbor florida
    oh ok sweet when ever i finish my car ill pm you and we can figure something about.
  1. pcm tune
    By Erik Adam Rodriguez in forum General Tech Discussion
    Last Post: 10-02-2012, 06:58 PM
  2. tune up
    By 1996pontiac in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-18-2011, 08:32 AM
  3. ok tune
    By qksilver in forum PCM Tuning
    Last Post: 10-27-2010, 10:40 PM
  4. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  5. PCM Tune
    By csssaint12 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-01-2010, 08:32 PM
