Thread: I think I have a vac leak
Results 1 to 4 of 4
  1. #1 I think I have a vac leak
    SE Level Member gtpterp's Avatar
    Jul 2011
    MD
    Hey guys,
    While driving yesterday I could barely here my supercharger (I have a 3.4 pulley). The whine is usually loud and very noticeable. I wanted to check my boost so I checked it out on my torque app (never had any problems with showing how much boost I was under). The psi was running -20 and at WOT it was getting to around -5 psi I think. Usually it gets to about 9 at WOT and -10 otherwise. I'm thinking its a vac leak, any other ideas? If it is a vac leak what is the best place to search and how
    '00 GTP: TOG headers with high-flow Cat, Borla exhaust, 3.4 Pulley drop, 180* Tstat, NGK TR55
  2. #2 Re: I think I have a vac leak
    Look over your vacuum hoses and if you don't see anything out of the ordinary check around with a can of carb cleaner.
  3. #3 Re: I think I have a vac leak
    St. Louis
    Check the vacuum T under the snout of the S/C. This is a common place for them to crack/leak.
  4. #4 Re: I think I have a vac leak
    Jul 2011
    MD
    Fixed. Was my evap vacuum line. Thanks for the help!
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  5. oil leak on 3.4 dohc. Not that oil leak.
    By 67GTO in forum General Tech Discussion
    Last Post: 06-14-2010, 11:52 AM
