Thread: Need Imput on Roller Rockers
Results 1 to 20 of 40
  1. #1 Need Imput on Roller Rockers
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    Should I get Yella Terras or SLP's and why?
  2. #2 Re: Need Imput on Roller Rockers
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    SLP was made by Yella Terra....they are one in the same.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: Need Imput on Roller Rockers
    Feb 2009
    flintnasty MI
    neither.
  4. #4 Re: Need Imput on Roller Rockers
    neither.
    Scott.. It might help folks to understand your reasoning.. if you gave some.
    Most read Scott's response as a joke or someone goofing off. However Scott and Zoomer had quite a thread about this on CGP. It appears that the square tip on the stock rocker may actually be closer to 1.8 ratio at the end of the tip. The one thing I haven't seen though is someone measuring to confirm that.
  5. #5 Re: Need Imput on Roller Rockers
    Jan 2013
    Australia
    ?? do you mean modified stock rockers are actually closer to 1.8 ratio?
  6. #6 Re: Need Imput on Roller Rockers
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    I have yella 1.9's on my GTP.They work well,but are pricey.I wish i would have gone cam tho.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  7. #7 Re: Need Imput on Roller Rockers
    Slower, Lower Delaware
    I have Yella Terras on mine. I like them. I don't mind paying for quality. I'm still not interested in a cam at this time.
  8. #8 Re: Need Imput on Roller Rockers
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Definatly worth it.
  9. #9 Re: Need Imput on Roller Rockers
    Jan 2009
    Tallahassee, FL
    I like my YTs as well.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #10 Re: Need Imput on Roller Rockers
    GT Level Member ls1camino's Avatar
    Laurel, MD
    I run Yella Terras on both of my cars. They work well as long as you properly measure pushrod length.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  11. #11 Re: Need Imput on Roller Rockers
    Jan 2009
    Tallahassee, FL
    YTs should come with the correct pushrod length already.
    77 Morris Garage B
  12. #12 Re: Need Imput on Roller Rockers
    Laurel, MD
    Quote Originally Posted by Sandman View Post
    What happens when you change cams, lifters, head gaskets, or machine the deck on the block or heads?
    Pushrods are the last thing done after a motor is assembled and are measured to your specific setup.
  13. #13 Re: Need Imput on Roller Rockers
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by ls1camino View Post
    Well of course, but if nothing else is changed then I don't have yo measure for the length when they come with them.
    77 Morris Garage B
  14. #14 Re: Need Imput on Roller Rockers
    Bingo, that is what Scott has suggested in that post. Thing is...no one ever seems to have measured.
  15. #15 Re: Need Imput on Roller Rockers
    Jan 2013
    Australia
    I see, that must be why modified 1.9's are more likely to work with stock springs?
  16. #16 Re: Need Imput on Roller Rockers
    May 2008
    Schuyler, NE
    You will make more power with a stock style rocker than rollers.
  17. #17 Re: Need Imput on Roller Rockers
    Tell me why. Don't you have a cam?
  18. #18 Re: Need Imput on Roller Rockers
    Do you have evidence to support this claim? You and dark seem to be against everything but never provide any reasons why or ever give any valid proof of why either. Just like in the thread where you both stated that stock manifolds are better than headers. I'm not saying that I doubt what you say but its really hard to believe you when you give no proof other than because I said so..... all I'm saying is I want to know why.
  19. #19 Re: Need Imput on Roller Rockers
    Feb 2010
    Cleveland
    /\ Cannot believe that. they are heavier by about 40 grams a piece and from what Intense always said the 1.9's were really only 1.8's.
  20. #20 Re: Need Imput on Roller Rockers
    Nov 2011
    NY
    I'm not gonna bash GTP or Dark, I've learned that although they have experience with this platform, like all else you find on the Internet, their word isn't and shouldn't be taken as Gospel! There have been times they offer good info, or at least stimulate though towards addressing a certain issue. Mostly, it's diatribe without substance, but if you read what they say and research, there's some good info. to be found. Doesn't matter who's right or wrong...
    Bottom line is it all depends what you want out of your engine!!!
    I've installed my YT's 1.9's and I'm completely happy with them. I did not and do not still after installing them want a cam. The slight increase of breathing has definitely given a better feel on the top end with the YT's. And for my $, I'd rather have rollers over stocks any day of the week. If you're looking for the same performance out of rockers as a cam you will be disappointed as they are completely different.
    A decent read on high ratio rockers...
    Higher Ratio Rocker Arms
    Good Luck!
  1. Which roller rockers?
    By spina74 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2009, 08:11 PM
