Thread: Need Imput on Roller Rockers
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: Need Imput on Roller Rockers
    May 2008
    Schuyler, NE
    I've said this many times on here. Stock style rockers are not a fixed ratio. The higher the lift, the higher the multiplication ratio.
    Since roller rockers have a roller tip, their ratio will always be whatever they are rated at.
    ZZP has a great article on their site regarding this. Plus, lots and lots of discussions on clubgp as well.
  2. #22 Re: Need Imput on Roller Rockers
    So.. anyone want to tell me why ZZP still sells rockers knowing this info?
  3. #23 Re: Need Imput on Roller Rockers
    May 2008
    Schuyler, NE
    They are good at making money, I guess.
  4. #24 Re: Need Imput on Roller Rockers
    Feb 2009
    flintnasty MI
    Johnbobs lt1 camaro upgraded to roller rockers... so if i put them on my gtp it would be hella sweet obviously.
  5. #25 Re: Need Imput on Roller Rockers
    LOL..
    Either of you guys have an idea of what ZZP's modded 1.9's are likely to come out at since the stocker 1.6's could be close to 1.8 at the tip?
  6. #26 Re: Need Imput on Roller Rockers
    May 2008
    Schuyler, NE
    I've never gone through the trouble of measuring. I've got like 19 motors sitting around.....maybe one of these days I should tackle that project.
  7. #27 Re: Need Imput on Roller Rockers
    I'd be super interested in seeing actual numbers on this.
  8. #28 Re: Need Imput on Roller Rockers
    May 2008
    Schuyler, NE
    Maybe when we are done planting I will get some time to mess with it.
  9. #29 Re: Need Imput on Roller Rockers
    I'd offer up a 6 pack as payment of the time.
  10. #30 Re: Need Imput on Roller Rockers
    May 2008
    Schuyler, NE
    I've never been one to turn down free beer.
  11. #31 Re: Need Imput on Roller Rockers
    So would longer push rods be better?
    Sent from my mobile office.
  12. #32 Re: Need Imput on Roller Rockers
    Feb 2009
    flintnasty MI
    the test rig is tough to setup.. you need to dials setup to read good, and something to setup pushing on the rocker. The best bet would be to do it with a spring on the head, but it would probably be way easier to measure theoretical no deflection numbers as deflection in the real world is different than what you would find on a bench (inertia plays a big role).
  13. #33 Re: Need Imput on Roller Rockers
    Slower, Lower Delaware
    Quote Originally Posted by slick2500 View Post
    The correct length would be best.
  14. #34 Re: Need Imput on Roller Rockers
    May 2008
    Schuyler, NE
    Yeah, it's going to be a project. That's for sure. But, the beer from Bill should help motivate me.
    We don't have dat dere fancy beer down here in the land of kernstalks and moo-cows.
  15. #35 Re: Need Imput on Roller Rockers
    SE Level Member 92bird's Avatar
    Colorado
    I've had YT 1.95 roller rockers on my GTP for 2 years, prior to that I had zzp modded 1.9 rockers. ET's improved 1 tenth and 1.2 mph consistantly at the track when I was supercharged. But I also upgraded valve springs at the same time as the yella terra's, so I'm not sure if its the rockers or springs. Springs are L76 with ls1 retainers..
    I'm turbo now and don't ever plan on going cammed. The car looses traction from the bottom of 2nd gear with 2.93's and a stock l67 torque converter at high elevation (thin air) here in Denver. More power would only be useful at the track on slicks at this point..
    2000 GTP: ZZP Z7 turbo kit,Precision 5858cea Billet turbo,F&R p-logs,L26 upper/lower,HV3 insert,60lb inj,L67 Throttle/MAF,1.95 Yella Terra rockers,PAC 105 springs/titanium retainers,3" exhaust,full suspension,Self-built 4t65e with zzp 300m input shaft, TEP 7/8" 2.93 chain set, blue plate clutches,PI 2800 stall billet cover converter
  16. #36 Re: Need Imput on Roller Rockers
    With all that corn you should have plenty of shine. But, I don't think you want to work while partaking of that.
  17. #37 Re: Need Imput on Roller Rockers
    Feb 2009
    flintnasty MI
    Quote Originally Posted by 92bird View Post
    I can say from experience that it was the springs that helped. Stock springs on 1.9 moddeds just plain dont work.
  18. #38 Re: Need Imput on Roller Rockers
    May 2008
    Schuyler, NE
    Quote Originally Posted by Sudden View Post
    LOL...I'm getting too old for that stuff.
  19. #39 Re: Need Imput on Roller Rockers
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    You can never be too old for that stuff.
  20. #40 Re: Need Imput on Roller Rockers
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    Thanks for the input everybody
  1. Which roller rockers?
    By spina74 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2009, 08:11 PM
