Thread: Wiring an IC pump?
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Wiring an IC pump?
    Apr 2011
    Vassar, Mi
    When you trigger you IC pump relay off of you fuel pump relay it will run for a few seconds when you first turn on the key. If its on all the time your just hooked into key on power. It will work but its not ideal, mine is hooked to the fuel pump relay wire in the back of the fuse box. Just did it 2 weeks ago, couldn't tell you what color the wire is though, I wired 40 other connections that week.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  2. #22 Re: Wiring an IC pump?
    GTX Level Member crbquist's Avatar
    Massachusetts
    Quote Originally Posted by Anthony Smith View Post
    This is what I need to do, I just have no idea which wire it is.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  3. #23 Re: Wiring an IC pump?
    Chris.. Do you have any schematics for the car? Wait a second, I might have one in photobucket. All you need is the position on the back of the fusebox. It'll end up being a wire that is a common enough color, so you need the position to check it with a test light.
    Looks like I only have the Regal one in PB. IT'll give you an idea of what you are looking for though.
    This diagram is saying it's a gray wire on connector two at position A6. IIRC that may be the same position as the GP. If you look close at the sides of the connectors on the back of the fusebox, they are labeled.
  4. #24 Re: Wiring an IC pump?
    Massachusetts
    Bill, we still couldn't quite figure it out. Each wire we initially thought was the correct one kept triggering the test light with the key in the run position. Would you mind if I stopped by sometime soon to get your consensus?
  1. Intercooler relay and pump wiring?
    By Pure2sin in forum General Tech Discussion
    Last Post: 03-29-2015, 02:39 PM
  2. Intercooler pump wiring
    By triebenbach07 in forum General Tech Discussion
    Last Post: 05-09-2012, 09:16 AM
  3. Intercooler pump wiring
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2012, 05:39 AM
  4. Bosch IC pump wiring
    By Taz Magister in forum General Tech Discussion
    Last Post: 10-11-2011, 12:30 PM
  5. Intercooler Pump Wiring
    By QwikGT in forum General Tech Discussion
    Last Post: 10-31-2008, 08:38 PM
