Thread: Replacing LIM
Results 1 to 11 of 11
  1. #1 Replacing LIM
    Slower, Lower Delaware
    I'm doing an intercooler. I've searched and read and watched videos but there are a couple of questions I still have. Does the 2005 GTP have coolant o'rings that have to be placed under the blower? Should I replace the o'rings on the injectors before putting them back in?
    TIA.
  2. #2 Re: Replacing LIM
    It does have the o rings. I usually don't replace the injector o rings unless they look bad.
  3. #3 Re: Replacing LIM
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Injector o-rings are cheap.
    You don't have too, unless they look bad/broken, but it will be a good idea since they aren't expensive.
    Just one more thing you do not have to worry about.
  4. #4 Re: Replacing LIM
    If you are intercooling. You won't keep coolant flowing. I'd suggest plugging them as described in the "how to mod a lim" post. That way if you ever need to pull the IC, you won't have to drain coolant.
    04-06 they are part of the gasket. They are nearly the same thickness as the 97-03 yellow rings.
    07-08 gasket they are inlaid because the manifold has no indents for the ports.
    [IMG]
    http://i20.photobucket.com/albums/b2...r/IMG_3593.jpg[/IMG]
  5. #5 Re: Replacing LIM
    Where's the "how to mod a lim" post. I searched and did not find it. What do you mean "You won't keep coolant flowing"
  6. #6 Re: Replacing LIM
    Type "Eas y" without the space and my name in the advanced search. You'll have every how to I've done.
  7. #7 Re: Replacing LIM
    Very cool. Thanks a lot. I'll try those plugs. I don't have the frijoles to grind on my LIM. And now I'll have to read the whole "How to" section to see what I'm missing.
  8. #8 Re: Replacing LIM
    Just use Eas y ... it filters my stuff. Oddly..I had found I used that word a lot in all the write ups.
  9. #9 Re: Replacing LIM
    I should pay closer attention. The modified LIM I got from ZZP with the intercooler has the holes welded up. And it came with the new GM intake gaskets. I think all I have left is to pick up o'rings for the FI. They sent me beautiful fuel rails and not even one o'ring.
  10. #10 Re: Replacing LIM
    That's pretty normal.
  11. #11 Re: Replacing LIM
    Fel-pro fuel injector O-rings ES 70599. Fits both upper and lower?
  1. Replacing the BCM on a 08?
    By veener79 in forum General Tech Discussion
    Last Post: 03-15-2013, 07:32 PM
  2. Should I try replacing my PCM?
    By 50Coupe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-28-2011, 04:17 PM
  3. Replacing suspension
    By zildjian102 in forum Brakes/Suspension/Chassis
    Last Post: 09-09-2010, 07:13 PM
  4. replacing my a4 - gtp or gxp?
    By burninator in forum Off Topic Discussion
    Last Post: 06-30-2010, 06:50 AM
  5. Replacing...
    By BwolfGT in forum Off Topic Discussion
    Last Post: 09-13-2009, 10:17 PM
