Thread: let's talk exhaust components
Results 1 to 19 of 19
  1. #1 let's talk exhaust components
    Apr 2013
    Michigan
    so i been doing some searching but haven't quite found a answer yet so maybe someone can help me. i plan on building up my gtp mildly nothing huge just yet lol. How are header's off ebay? any good worth the $200? i was gonna then do 3" zzp downpipe to 2.5 pipes to mufflers not sure on mufflers yet. made a 4" fwi already deff noticed diff in sound as well as my gas mileage actually went up. then maybe later a 3.4 pulley but idk. thanks for help in advance guys
  2. #2 Re: let's talk exhaust components
    antioch ill
    get speed daddy headers cut out the flex pipe weld in a new peice. then just the rest of the exhaust stock
  3. #3 Re: let's talk exhaust components
    Apr 2013
    Michigan
    really stock exhaust y stock? i know deff need mufflers for sure cause mine r shot
  4. #4 Re: let's talk exhaust components
    antioch ill
    unless you are buying borlas i wouldnt waste the money. the stock catback is good till like 350 whp
  5. #5 Re: let's talk exhaust components
    Apr 2013
    Michigan
  6. #6 Re: let's talk exhaust components
    Apr 2013
    Michigan
    what can i do with stock muffers then just to make em last
  7. #7 Re: let's talk exhaust components
    Apr 2013
    Michigan
    gotcha bro and thanks but what can i do with stock mufflers to make em last and what are some nice tips
  8. #8 Re: let's talk exhaust components
    Apr 2013
    Michigan
    oh ok but no only reason why said mufflers mine r all rusted out bad shape.
  9. #9 Re: let's talk exhaust components
    Jan 2009
    Tallahassee, FL
    Not only does it outflow what most people will need, it sounds the best as well. Just get some nice tips.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #10 Re: let's talk exhaust components
    antioch ill
    yup offer 200 they will take it and hurry they sell out fast
  11. #11 Re: let's talk exhaust components
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    if yours are rotted out get a new set
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  12. #12 Re: let's talk exhaust components
    Jan 2009
    Tallahassee, FL
    Since yours are rotted out just get some new ones. As far as tips just find what you like and get them.
    77 Morris Garage B
  13. #13 Re: let's talk exhaust components
    GT Level Member fri3dchick3n's Avatar
    Alaska
    I have SD Headers, No CAT and my car sounds like poop at WOT. : \ Stock Muffies too.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  14. #14 Re: let's talk exhaust components
    Nov 2011
    NY
    If you're not going aggressive pulley drops or turbo, cam, etc., there's no need to get crazy with exhaust. Stock cat back (2.5") is fine and dandy. Why? Because it provides enough flow for the HP as mentioned. Resonator kills the rasp, so if that's still good I'd keep it and just replace what's broken/rusted out.
    There are lots of muffler combo's out there and is a well worn topic with a horse beaten dead! I don't usually say this, but you should really use the search function and google! There's gonna be hundreds of links to help you decide.
    I installed Pacesetter headers and Catback (3" to the rear), hi flow cat, summit racing resonator (30") with Hooker Maxflow mufflers and love the sound. But it's like anything else, you say potAYYToe, I say potAAAtoe!
    Good luck!
  15. #15 Re: let's talk exhaust components
    Quote Originally Posted by coolone View Post
    2.25" before the Y in the back, 2.0" after the Y.
    just to keep from spreading lies...
  16. #16 Re: let's talk exhaust components
    Florida
    I have a magnaflow muffler, to a glass pack, then to a Y and two tips. The system is lighter then stock and flows much better. Also it sounds pretty good too a little drone on the hwy but great at wot or idle. But I suspect most of the drone is from the exhaust leak I have where I have to cut out part of my exhaust to do the headers. When the topswap is done I will have it welded up and it should go away
  17. #17 Re: let's talk exhaust components
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Trying to find a link on my impala forum but cant seem to track it, but overkill made a thread about how catback, were bigger on 06+ impalas.
    I know my 08 impala SS catback sound alot different then grandprix catbacks.
    Gives you some more options if you looking for used catbacks.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  18. #18 Re: let's talk exhaust components
    Apr 2013
    Michigan
    well came across deal on craigslist be picking em up friday for two flowmaster 40 series mufflers $50 for the pair. local pick up to. then start to save up for headers etc...
  19. #19 Re: let's talk exhaust components
    Feb 2008
    You will hate those Flowmasters at every rpm above 1000...
    I am extremely happy with my Magnaflows and a glass pack for a resonator. Smooth, noticeable burble at idle. Nice tone and volume (not too loud) at cruise. And a roar that isn't too ricey/raspy at WOT.
    Sent from my SkyRocket
  1. Replacing AC components
    By vertebrate in forum General Tech Discussion
    Last Post: 08-30-2012, 11:06 AM
  2. Interior Components
    By cowmilker08 in forum General Tech Discussion
    Last Post: 04-01-2009, 01:59 PM
  3. L67 components
    By straight_upprix05 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2008, 08:01 PM
