Thread: EGR Valve?
Results 1 to 5 of 5
  1. #1 EGR Valve?
    GTP Level Member GTPluv's Avatar
    Enid,Ok
    Well, I must have the crappiest GP around. It can't go one week without something f'ed up on it. I replaced the O2 Sensor and one of the coil packs. That worked for a min. Got my sunroof settled (Thank You GP fellows). It started cutting out again every now and then. Went to AZone and it came back as the EGR valve. The guy told me it may be 10 degrees off?? (Computer said) He said it could be dirty. Tonight I looked on the google and it also said it may just have carbon built up to clean the intake. So, what do yall recommend? Be gentle (and cheap)
  2. #2 Re: EGR Valve?
    Oklahoma
    Moved this to the correct section, I would also read this information:
    http://www.grandprixforums.net/f14/a...read-6828.html
    Post #7
  3. #3 Re: EGR Valve?
    Feb 2008
    Quote Originally Posted by GTPluv View Post
    10 degrees off?? umm not sure what you are referring to there, the EGR valve can only go on 1 way. You could have carbon build up, but I haven't seen to much of that with our engines. There are ways you can test the EGR valve.
    When was the last time a tune up was completed?
  4. #4 Re: EGR Valve?
    Bastard Reptile's Avatar
    Kansas City, MO
    Yeah, either it opens or not. That doesn't make sense.
    If it turns out you need one, I have several that you can have for just shipping.
  5. #5 Re: EGR Valve?
    Enid,Ok
    Sweet!
    PM sent
  1. Is There An EGR Valve Workaround For a '97?
    By 1997gpgt in forum Off Topic Discussion
    Last Post: 08-25-2008, 07:41 AM
  2. 90# valve springs on '97 heads
    By DanGTP in forum General Tech Discussion
    Last Post: 08-11-2008, 01:32 AM
  3. Location of PVC Valve
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 08:49 AM
  4. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
