So I just picked up a gen V, LIM, heads, and throttle body. They'll be sitting for a while before I get around to using them. Right now they have the usual amount of gunk on them from just being pulled from a motor. Since they'll be sitting a while I'd like to get them all cleaned and put away nicely so they stay in good condition and don't stink the garage up. Basically the only thing that really needs a cleaning is the heads. How would I do this and is it even good for them? I don't want to clean the rotors of the sc or anything.
Now my other question. What's the best way to polish a supercharger? I have a dremel with all the polishing bits and plan on using that. Is there a certain technique that should be used? Will I need to take the rotors out or should they be ok since the outlet will be down?
