Quote Originally Posted by dbextreme View Post
I highly doubt it's an electrical connection to sensor issue, I just used them as examples . But Google can be your friend regarding sensor locations. There's not much running down the back of the motor: MAP, Rear Knock, O2's, Oil Pressure, Speed Sensor... Might be missing one or two. There should be a vacuum routing sticker under your hood somewhere showing you what all's back there. I know there's the EVAP and MAP above the valve cover, both have those brittle vacuum lines running to them.
Hope others chime in to, I'm by far smart when it comes to these cars.. LOL I understand the frustration, I spent 4 hours today tracking down an electrical gremlin in my car...
I'm more of a 4-5 wire hook up late 60's early 70's model car guy myself (I'm only 33 though LOL) but I'm learning more about the computer controled stuff. My LT1 car is fun and still pretty simple. if it blows I'll do an LS swap probably, might just build the LT1 to a 383 and be done with it but that's later down the road.
yea man LS is the way to go A LOT OF mods for it the possibilities are endless. But then again im sure its the same for older stuff. Its just what I've grown up on and own so yea but cant go wrong with it. Thanks for all the help.
Quote Originally Posted by Phil99gp View Post
The plugs you Bought are terrible. Take them out and note how the porcelain is all cracked on more than half of them. Replace with autolite copper cores (either 606 or 605) and enjoy a smooth ride again.
Thank me later.
You think so I might just go ahead and swap em, have you had issues with these plugs?
