Thread: Dont do this
Results 1 to 5 of 5
  1. #1 Dont do this
    Texas
    Ok so I am swapping out my old 3.8 sc motor in my 97 grand prix gtp. The motor had over 216000 miles and it finally gave out. Soo while I had the motor out I figured it was a good time to clean up the engine bay. Had oil caked all over. I sprayed some degreaser and decided to have my brother pull me to the car wash down the street. Was thinking the high pressure would be best to clean up the oil. Well at that time I did not realize the passanger cv shaft was resting on the frame of the car. While I was pulling the car the shaft was rotating on the frame making a horrible sound and greese was flung all over the area I just cleaned. While I was replacing the cv shaft I found out the shaft completly came out of the inner housing assembly. Luckly I was not far from the house.
  2. #2 Re: Dont do this
    GT Level Member Shiftingshaddow's Avatar
    KC
    i will try to remember not to do that
    i know you're bummed but i had to laugh.
    216 isnt that high, though.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  3. #3 Re: Dont do this
    Yeah..I don't do that. Hence why you see that end of the trans supported in any pics I take. Cause..there's nothing holding it BTW.
  4. #4 Re: Dont do this
    Texas
    I guess I found out the hard way.
  5. #5 Re: Dont do this
    Didn't you support the trans when you pulled the motor, say with a jack?
  1. Dont have a name for it yet, but here it is.
    By Mikey Bonefas in forum Members Rides
    Last Post: 01-06-2013, 10:18 AM
  2. Dont know how but I did
    By foytz14 in forum Track Sessions and Kills
    Last Post: 09-27-2011, 10:36 AM
  3. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
