Thread: Getting rid of KR?
Page 1 of 9 123 ... LastLast
Results 1 to 20 of 167
  1. #1 Getting rid of KR?
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    I'm looking for ways to get my KR down. I'm seein about 4.5-5* of knock. It's only happening when it shifts at WOT. Scanning with an aeroforce running 91 octane.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  2. #2 Re: Getting rid of KR?
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    put in 93 octane, headers, rockers, 2.5-3" downpipe, cam, port blower.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  3. #3 Re: Getting rid of KR?
    May 2008
    Schuyler, NE
    What are your mods?
  4. #4 Re: Getting rid of KR?
    GTP Level Member GrandPrixgtp2000's Avatar
    Madrid Iowa
    Go e85
  5. #5 Re: Getting rid of KR?
    Jul 2011
    Cheyenne
    I've got a 3" catless DP. ZZP wires. ZZP 1.0 PCM. K&N cold air. Still on stock pulley. Trying to get this knock down so I can drop to around a 3.5.
    We can't get anything higher than 91 octane here
    Also, I'm seeing around 5.5 for boost numbers. Is that normal?
  6. #6 Re: Getting rid of KR?
    Put stock pcm back in it kr will go down
  7. #7 Re: Getting rid of KR?
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    prob not it will prob go up to 8 kr with stock pcm get some headers and get the false knock kit
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  8. #8 Re: Getting rid of KR?
    I had less kr on stock tune
  9. #9 Re: Getting rid of KR?
    Nov 2011
    NY
    Headers, Headers, Headers... Then tune... If ya want, port the S/C, TB, colder t-stat and tune it all in... More flow is better, but gotta tune it. Tuned PCM will help get rid of KR. Not the boxed variant. Those will only take you so far. That 91 Octane needs to go up... Did I forget to mention Headers?
  10. #10 Re: Getting rid of KR?
    Feb 2009
    flintnasty MI
    Headers suck and tuning is pointless on most cars. If you have that much kr you have a mechnaical issue. 91 octane isnt that bad.
  11. #11 Re: Getting rid of KR?
    Pennsylvania
    ZZP sparkplug wires have a history of issues. Try swapping back to stock to see if it changes anything.
    Ensure that your downpipe does not have an exhaust leak.
    Check for vacuum leaks.
    Clean your MAF sensor and throttlebody.
    Check your receipt for the ZZP PCM to ensure that it's tuned for 91, not 93.
    after all that... fresh fuel filter, check sparkplug gaps (0.060), replace with new if near 100k or over.
  12. #12 Re: Getting rid of KR?
    Jul 2011
    Cheyenne
    I know that I have a bit of a leak where my down pipe goes into my resonator. Could that really be the cause of it? I know my vacuum lines are good, when I hooked up my boost gauge I ended up replacing half of the lines.
  13. #13 Re: Getting rid of KR?
    Nov 2011
    NY
    Headers suck? Hmmmmm...
    I guess then the same can be said for porting and polishing heads? Lmao!
    ANY flow mods... On intake and especially the exhaust side with these engines helps. And tuning then afterwards most certainly does help, if not eliminate knock.
    I had from +5* kr prior to headers... 3-5* afterwards, barely 1/2* now after 1.9 YT RR's and 3" exhaust. And that's with just beginning (learning) to tune. So...
    Yeah ok, I totally disagree with you! Respectfully of course! As I've been told every 3.8 is different. ; ) maybe your experiences are different.
  14. #14 Re: Getting rid of KR?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Maybe he meant headers suck to install??? I know afterwards they look and flow much better!!! :-D
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  15. #15 Re: Getting rid of KR?
    May 2008
    Schuyler, NE
    Headers are pointless on a bolt-on car. I'm not sure why they are pushed so hard around here for 3.4 to stock pulley cars. At that level, they aren't worth the maintence headache that they cause.
  16. #16 Re: Getting rid of KR?
    Feb 2009
    flintnasty MI
    headers offer the least bang per buck of any mod, even at these chinabay prices. They are a pain in the ass to keep from leaking if you can even pull it off, and you might pick up .1 and a mph in the quarter with extensive mods... I have never seen a 3.4 pulley car go faster with them.
  17. #17 Re: Getting rid of KR?
    Feb 2009
    flintnasty MI
    Quote Originally Posted by coolone View Post
    You do know that I had a 3.4 pulley and a tuner EIGHT years ago right? You were probably not even old enough to drive a lawnmower.
    I have been doing this 3800 "thing" long enough to say what I say with knowledge and experience behind it.
  18. #18 Re: Getting rid of KR?
    The Boss Iceman6669's Avatar
    Jun 2011
    See that just dont make any sense to me... Headers allow the exhaust to flow better... Plus headers are almost as much as a PLOG and DP combo...
    2011 F-150 Yote powered
  19. #19 Re: Getting rid of KR?
    May 2008
    Schuyler, NE
    Stock manifolds aren't even close to being out-flowed at a bolt-on level. Bigger isn't always better.
  20. #20 Re: Getting rid of KR?
    new britain, ct
    headers suck? i didnt realize flow was bad.
    07 Black GXP.
rid
