Thread: what spark plug should i get.
Results 1 to 11 of 11
  1. #1 what spark plug should i get.
    Hallstead PA
    I was wondering what the best plug I should get and your opinions. its a 97 gtp, cold air intake, 140 degree t-stat (was in it when i bought it) slp cat back, msd coil packs and wires.
  2. #2 Re: what spark plug should i get.
    Didnt know they made a 140ยบ thermostat.
    Swap that for a 195 when you buy plugs.
    I would get rid of the MSD coils aswell, they are known to cause problems down the line.
    As for plugs just get some stock repalcement AC delco 41-101 Iridiums, I don't see a need for you to run anything differen at this point in time.
  3. #3 Re: what spark plug should i get.
    Hallstead PA
    I didnt think they did either but thats what the previous owner told me he put in it. Does it hurt the motor or make any power difference? I want to change the coolant and thermostat soon as its starting to warm up finally. I do have a new set of coils bc i heard that the msd coils go bad so im prepared now. Also i forgot to mention that the previous owner dropped a pulley size as well. that makes a difference, he said he only went one size down but couldnt remember what size it was.
  4. #4 Re: what spark plug should i get.
    I think he doesnt know much about cars, there isnt a 140 option, I bet its a 160 or a 180, which there is no need to run them. If the 160 is in there its far too cold for the car, mpgs suffer and car never reaches proper temps on the inside.
    Measure the pulley with a ruler or a digital or non digital caliper. I bet its a 3.5 or 3.4, but either way it should come off unless you plan on running more exhaust mods very soon.
    The stock manifolds cant handle the extra air being brought in by the smaller pulley and causes alot more stress on the engine, pistons etc etc and can make a piston chip and your out a motor. I would swap it back to a stock pulley.
  5. #5 Re: what spark plug should i get.
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Copper to avoid knock. AL 106 or 105s stock.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  6. #6 Re: what spark plug should i get.
    Florida
    there aren't 106 105's they are 606 or 605. the stock plug would be a 606. I have heard to run copper or iridium. with boost it is said they do not like the platinum plugs. and i know that even NA they don't like double platinum. from personal experience in warm climate I deff recommend a 180* stat for any vehicle. up north yeah you might be better off with a 195* regarding the MSD coils. there are two diff types of MSD coils for these cars. ones look just like stock and others have a more square shape to them. the ones that resemble the stock plug are the ones that had the issues. I have been running a set of the square ones for 7 years now and they were used. I got them off a GTP that i parted out. Now I will say that they do not increase performance at all and I would not ever buy them myself. you might be able to sell them and get some money
  7. #7 Re: what spark plug should i get.
    Nebraska
    Oops yeah 606 or 605, long week. Personally I got the AL606's just because I couldn't find a lower heat range plug where I live. If you do go copper replace them every 15k these cars use waste spark system, eats these plugs up.
  8. #8 Re: what spark plug should i get.
    Pennsylvania
    Quote Originally Posted by Z34Phoenix View Post
    Like 94GrandPrixSE said, it's about the waste-spark engine, not whether or not there's boost. Platinum gets brittle and breaks because it can't handle the abuse. Copper's soft enough not to break off in the engine, but doesn't last very long. Iridium does a great job.
  9. #9 Re: what spark plug should i get.
    GTX Level Member blackflag's Avatar
    Virginia
    Quote Originally Posted by jakeb157 View Post
    stock. and go back to the stock coilpack. I also am assuming your joking on the 140* thermostat. Your car would act retarded.
  10. #10 Re: what spark plug should i get.
    Pennsylvania
    At that low a temp, it would probably be like running without a thermostat - possibly water in oil because it doesn't boil off, decreased efficiency, etc.
  11. #11 Re: what spark plug should i get.
    Nebraska
    I agree with Blackflag, AC delco Coilpack > MSD. As for thermostat 195 if your stock, the knock sensor doesnt even come on until 160.
  1. Spark Plug Gap
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 10-14-2012, 09:57 AM
  2. which spark plug?
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2012, 07:39 PM
  3. what spark plug should I use?
    By jsaylor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2012, 11:44 PM
  4. Spark plug gap
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 01:55 AM
  5. Spark plug
    By zildjian102 in forum General Tech Discussion
    Last Post: 03-01-2011, 02:48 AM
