Thread: Bypass Valve Stuck Open
Results 1 to 8 of 8
  1. #1 Re: Bypass Valve Stuck Open
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    Ya just unplug the vac line to the sol and unplug the connector to the bbv problem solved
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  2. #2 Re: Bypass Valve Stuck Open
    SE Level Member bayouboy's Avatar
    Apr 2013
    United States
    Quote Originally Posted by 00grandprixgtp View Post
    wow that simple... thanks. do i reconnect everything afterward? Also will this reset the check engine light? The remote start is not working due to the check engine light.
  1. Throttle got stuck wide open
    By SilvaMan61 in forum General Tech Discussion
    Last Post: 02-28-2013, 04:01 PM
  2. Boost Bypass Valve stuck...?
    By villanex in forum General Grand Prix Discussion
    Last Post: 06-17-2012, 11:12 AM
  3. Door Signal stuck open on DIC
    By thunder71173 in forum Audio, Security & Visual Electronics
    Last Post: 01-18-2011, 07:39 PM
  4. sunroof visor stuck open
    By hourang in forum General Tech Discussion
    Last Post: 06-30-2010, 04:42 PM
  5. EGR is stuck in open
    By shawnz90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 10:32 AM
