Thread: any way to check heads for cracks at home??
Results 1 to 10 of 10
  1. #1 any way to check heads for cracks at home??
    SE Level Member gixer2000's Avatar
    Braintree, ma
    im still swaping over my l67 stuff to me l26 short block. I noticed when I pulled my l67heads(first time) that it looks like there are small cracks between all the valves on the rear head. Im going to use a wire brush on the bowls to clean them up in the am and see if i can tell if they are cracked.I didnt notice anything wrong with the car before it spun a bearing but would i even notice if the heads where cracked? Is there a way to check these at home or just visual inspection?? any one have any pics of cracked heads so i know what to look for??
  2. #2 Re: any way to check heads for cracks at home??
    Barksdale AFB, LA
    That's a common area for cracks in 3800 heads. Only way I know of to really check for cracks on iron heads is to have them magnafluxed.
    2009 Subaru Impreza WRX STI
  3. #3 Re: any way to check heads for cracks at home??
    Oklahoma
    Unfortunately, Sabre is correct. Ive wondered though if it would be possible to use something like a powerful degaussing ring and an iron solution to do the same thing they do at the machine shops.
  4. #4 Re: any way to check heads for cracks at home??
    Braintree, ma
    yea im having a hard time finding a local machine shop. ill keep looking and i hope i find someone to check them
  5. #5 Re: any way to check heads for cracks at home??
    those cracks wont hurt anything. i wouldnt be worried in the least.
  6. #6 Re: any way to check heads for cracks at home??
    Braintree, ma
    are you sure they wont hurt anything?? i would think that when the cylinder is under pressure it could push it out the cracks past the intake and exhaust valves. but im not a mechanic so i dont know for sure
  7. #7 Re: any way to check heads for cracks at home??
    Barksdale AFB, LA
    I know Ed Morad won't sell you a set that have those cracks, and no vendor will accept some with cracks as core returns.
  8. #8 Re: any way to check heads for cracks at home??
    Feb 2008
    Don't worry about cracks in the heads....hmmm that's new!!
    Yeah I wouldn't use those heads. Gixer, you are basically right. Think loss of compression = loss of power = eventual drivability problems = miss fires and so on.
    Unless they can be fixed, I'm not sure how these heads hold after being repaired, someone else might know more on that.
  9. #9 Re: any way to check heads for cracks at home??
    Oklahoma
    Thats a first on me too. Cracks of any kind in the heads are usually bad and grounds to get replacements.
  10. #10 Re: any way to check heads for cracks at home??
    depends how bad they are. they tend to crack between the cylinders if i remember correctly. its pretty common if you look through a lot of heads.
    pour some water into the cylinders when they are sitting upside down. let it chill and see if the water gets out. if water is seeping through, air can get through way easier. i pulled off a set of my heads and noticed that ALL my valve guides were shot and a couple cylinders were leaking at the valve seals. from running no oil though.
  1. Ghetto Home theater :)
    By Toofastgs in forum Off Topic Discussion
    Last Post: 09-24-2008, 08:42 PM
  2. Just brought home my new car!!!
    By Quicklynx in forum Introductions/Noob Questions
    Last Post: 09-07-2008, 11:10 PM
  3. I finally found a home!
    By spank127 in forum Introductions/Noob Questions
    Last Post: 06-23-2008, 01:27 AM
  4. My new GTP is finally home
    By Mikel2k7 in forum Visual/Body Modifications
    Last Post: 06-20-2008, 11:30 PM
  5. Home?
    By GTPluv in forum Off Topic Discussion
    Last Post: 03-02-2008, 07:17 AM
