Thread: reduced engine power display after replacing lim gasket
Results 1 to 18 of 18
  1. #1 Re: reduced engine power display after replacing lim gasket
    Apr 2013
    Elizabethtown, KY
    After a couple of the replies i was on the trail. I had a tough time with which mao to connect. I put it on the oone that produced boost, but it caused rough idle. Then i reset it and it was perfect. Until i drove it a while tonight. Now i have a flashing cel and 6 codes. Back to the drawing board....
    I got stuck putting this car back together after a "friend" of mine tore it down to the block and left it. Its been quite an experience. Never had done more than a starter or alternator up to this point. Makes me really appreciate the car AND the forum.....
    She Passes Everything But A Repair Shop....
  2. #2 Re: reduced engine power display after replacing lim gasket
    GT Level Member Shiftingshaddow's Avatar
    KC
    i think flashing cel is a misfire or something else not good.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Car saying reduced engine power.
    By Louie3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 06:10 PM
  3. Reduced Engine Power is on after Replacing Battery
    By atmm72 in forum General Tech Discussion
    Last Post: 02-18-2013, 06:03 PM
  4. Reduced engine power. Help!
    By Jeremy1279 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 06:54 PM
  5. Reduced Engine Power???
    By 05gtPEACE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2010, 06:21 PM
