huh??????? thats not right. your putting oil in it right after your bolt it together..whats stopping you from going wot?
its not like it needs break in time.
some of the fill, plugs are Allen heads, and some are torx head. take a close look at yours.
also have a can of brake cleaner handy, it cleans up the inside of the snout and the sc side gears of the nasty sludge left behind.
dont forget the bolt that goes straight down, as none of the vids show that bolt, they just show the ones that are hidden under the snout.
take a few rags and lay them over the water pump area, and next to the snout, as oil will still leak out even though you pumped it out with a spray bottle. wipe up what leaks out, then spray it all down with brake cleaner.
and have some latex gloves to wear, as the oil stinks as bad if not worse then old used up rear end gear oil. and it stays with you for a few days. no soap works, just time.
