Thread: P0300 in need of help badly.
Results 1 to 4 of 4
  1. #1 P0300 in need of help badly.
    SE Level Member PTGsDaytona500GTP's Avatar
    Jul 2010
    Broadview Hts Ohio
    Had a misfire on cylinder 4 originally. So i did all the wires spark plugs and the 3 coil packs. Now im getting a p0300 code which is random multiple misfire. I am really low on options here i tried my best to do it without any guidance but i dont know what to do anyone who has some advice woukd be great. And no i didnt mix up the wires. Im going to grab some carb cleaner and see if its a vacuum leak.
    Thanks for your time.
  2. #2 Re: P0300 in need of help badly.
    If you only had a #4 before and now you have a multiple, you either have wires in the wrong locations or something else is off.
    What brand of wires did you use?
    Where they new?
  3. #3 Re: P0300 in need of help badly.
    St. Louis
    Also, what type of plug did you install? Hopefully the stock irridiums or a copper plug. No platinums.
    And double check your wire order using this link. I know you say you didn't mix them up, but it happens more than you would think.
    http://i33.photobucket.com/albums/d6.../plugwires.jpg
  4. #4 Re: P0300 in need of help badly.
    Jul 2010
    Broadview Hts Ohio
    spark plugs not sure (got them from autozone) i know they are pre-gapped and iridium tipped. wires i believe i got bosch wire set. Coilpacks i got bwd. ill double check to make sure they are not mixed up though. my car is stock btw.
  1. Car is missing badly
    By gtpzmdc in forum General Tech Discussion
    Last Post: 12-30-2011, 02:37 PM
  2. Badly Fluctuating RPM's
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 08:07 AM
  3. need help badly!!
    By Viperhunter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2009, 08:30 AM
  4. need your help badly trannyman
    By Zainoman in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 05-11-2008, 06:28 PM
