Thread: coolant elbow broken only 5 months old..?!?!?
Results 1 to 14 of 14
  1. #1 coolant elbow broken only 5 months old..?!?!?
    GT Level Member jdmgtp's Avatar
    MI
    so I'm driving after a wot run to 65, I see white smoke coming out of the back of my car and engine bay. I'm freaking out thinking I blew a head gasket. I park the car, open the hood and see coolant spraying out of the top coolant elbow.....I think this is strange since I just replaced it 5 months ago when I did my intake gaskets. I checked the radiator and oil filler for pressure, the oil for coolant and exhaust for coolant smell...nothing everything seems fine. I just find it strange the elbow I replaced 5 months ago just suddenly blows a leak. Is this normal? I already have the zzp aluminum ones so hopefulley it doesn't happen again. Just wondering if anybody has had an issue similar to this.
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  2. #2 Re: coolant elbow broken only 5 months old..?!?!?
    Ohio
    Mine were leaking after 3 months of new ones being installed.
  3. #3 Re: coolant elbow broken only 5 months old..?!?!?
    Banned
    Jan 2013
    the bandwagon follower aka noobiee
    yeah same here get those new one zzp sellls and then ur good for a while
  4. #4 Re: coolant elbow broken only 5 months old..?!?!?
    If you got the help ones then yeah its very probable. I have heard that the ones you get from a gm dealer are higher quality. I got the help ones from O'Reillys and after 3 months it popped out of the LIM it didn't break it just came out.
  5. #5 Re: coolant elbow broken only 5 months old..?!?!?
    Sep 2011
    Copperas Cove, TEXAS
    Crazy, that sucks, I have the help one, been doing good for three months now, hope the aluminum ones do the trick.
  6. #6 Re: coolant elbow broken only 5 months old..?!?!?
    Feb 2008
    The new Help plastic ones have been redesigned to correct the bending problem, but I'd go with the aluminum ones and a little bit if RTV on the o-rings for extra security.
    Sent from my SkyRocket
  7. #7 Re: coolant elbow broken only 5 months old..?!?!?
    Destroys cars izup69's Avatar
    Iowa
    I have replaced the coolent elbows so many times I have it down to a 10 min job. All the plastic ones from any parts store are crap..... You shouldnt have a problem with the alum ones from zzp. I had a set that was only about a month old blow out after passing a 85 ford f150. Its just a shame he had all that fluid on his windshield. Then he passed me as I was broke down on the side of the road.
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  8. #8 Re: coolant elbow broken only 5 months old..?!?!?
    Feb 2008
    I believe the aluminum elbows ZZP sells are Dorman Help pieces. I don't remember the part number, but I picked mine up from my local O'Reilly. They were hanging up in the back with their overstock.
  9. #9 Re: coolant elbow broken only 5 months old..?!?!?
    MI
    yeah, it took me just about an hour to do it, put some baby Vaseline on them before sliding them in. These zzp one will not break. That made in china crap was cracked. BTW it was the upper one. Thanks guys.
  10. #10 Re: coolant elbow broken only 5 months old..?!?!?
    Mar 2013
    Enfield, CT
    Sometimes if they get wedged in there wierd it puts too much stress on them and they snap. Ive made a habit of double checking that they have a slight wiggle after installing to be sure it seated comfortably.
    You shouldnt have anymore issues now that you threw a aluminum one in there.
    1999 Buick Regal GS.
    My Daily Driver and a work in progress
  11. #11 Re: coolant elbow broken only 5 months old..?!?!?
    Thats not true I heard the aluminum ones have bad orings.
  12. #12 Re: coolant elbow broken only 5 months old..?!?!?
    GTP Level Member 1ATony's Avatar
    mass
    We carry the replacement plastic and aluminum plastic heater hose elbows. Here's a link to them if anyone needs them.
    1997 - 2008 Pontiac Grand Prix Upper & Lower Plastic Heater Hose Elbow for V6 3.8L Pair
    1997 - 2008 Pontiac Grand Prix Upper & Lower Aluminum Heater Hose Elbow for V6 3.8L Pair
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  13. #13 Re: coolant elbow broken only 5 months old..?!?!?
    mass
    Here's a video that should help you guys out too.
    Tony
    1aauto.com
    SALES 888-844-3393
  14. #14 Re: coolant elbow broken only 5 months old..?!?!?
    Quote Originally Posted by slick2500 View Post
    GM O rings + aluminum elbows.
  1. coolant elbow broken inside engine
    By bjlandt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2013, 09:18 AM
  2. Any ideas? Broken coolant elbow won't come out of water pump..
    By CRU1Z3R in forum General Tech Discussion
    Last Post: 04-27-2012, 05:04 AM
  3. Broken coolant hose (elbow)
    By kking89 in forum General Tech Discussion
    Last Post: 09-29-2011, 10:34 PM
  4. coolant elbow broken, will not come out.
    By kingfish in forum General Tech Discussion
    Last Post: 02-26-2010, 08:17 PM
  5. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
