Thread: l67 timing chain removal help!!
Results 1 to 7 of 7
  1. #1 l67 timing chain removal help!!
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    im tearing down my motor and im at the timing chain and i cant seem to break the bolt loose hold the chain and sprocket off. any one have any ideas ?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: l67 timing chain removal help!!
    break the bolt loose hold the chain and sprocket off.. is that a sentance?
    Crawl under the car and remove the flex plate inspection cover. Put a pair of vice grips on the flex to hold it. Turn engine to have vice grips stop on trans housing. Then take bolt off.
  3. #3 Re: l67 timing chain removal help!!
    Sep 2011
    palm harbor florida
    soory i just woke up lol... i meant the bolt that hold the sprocket and chain on. the engine is out of the car im in the mitz of a rebuild. ill try that idea thanks !!
  4. #4 Re: l67 timing chain removal help!!
    If the heads are still on. Sometimes putting the plugs back in makes enough compression, but that bolt is pretty tight. The vice grips works everytime.
  5. #5 Re: l67 timing chain removal help!!
    I've.....in case you have no flex on it.
    I've.. put something in the valley to stop the balance shaft from spinning when you rotate the motor. That will also allow you to get the bolt off.
  6. #6 Re: l67 timing chain removal help!!
    we think a lot alike, bill. i've done all those things.
  7. #7 Re: l67 timing chain removal help!!
    Sep 2011
    palm harbor florida
    thats exactly what i did lol thanks again.
  1. 3.1 timing chain
    By bybeecl in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-01-2011, 11:56 AM
  2. timing Chain
    By Zach3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 11:12 PM
  3. timing chain
    By pure in forum General Tech Discussion
    Last Post: 08-16-2009, 02:00 PM
  4. Which timing chain to get.
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 09:01 AM
  5. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
