Quote Originally Posted by Charged97 View Post
yea i looked under the car and looked up and i seen oil resedu quit a bit all the wayup buy the valve covers would the oil pressure sensor spray or jusy leak u think it would spray all the way up there oh and 2 day nothing was leaking all day im confussed
Yeah the oil sensor is under the full pressure of the oil pump. So it could spray all over, but sometimes depending on the condition they can leak or seep oil too. If you see oil all the way down your engine block it's your valve cover gaskets. Keep in mind that the front valve cover has a recall on it. A way to see if your oil pressure sensor is leaking is to start the engine and get into a position where you could look directly at it. If it is leaking you will see it.
