Thread: Rough idle then smooths out.
Results 1 to 3 of 3
  1. #1 Rough idle then smooths out.
    SE Level Member PTGsDaytona500GTP's Avatar
    Jul 2010
    Broadview Hts Ohio
    Recently did my brake line replacements (both). Most recent work done. When i start my car after sitting for a good while it sounds as if i have a hole in my exhaust or like my motor is struggling best i can describe it. I do have a ses light on and its been like that for a minute, its a evap leak/gas cap code. Gas cap is new and i dont have money to have it looked at. But after 5min of idling it sounds normal and goes away. Im confused and want to fix this before it turns into something more expensive. Once again thanks for your time.
  2. #2 Re: Rough idle then smooths out.
    Confused on which brake lines you had done. You say both, yet there's four lines on the car.
    Seems like an exhaust leak.
  3. #3 Re: Rough idle then smooths out.
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    a few of these 3800s have been known to idle rough at start up when they are warm and have been sitting for 5 minutes or so, then it smooths out. i would try the coolant temp sens. it tends to get corroded and doesnt read for a few seconds ..cheap try.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. Rough idle
    By GTP2188 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2012, 03:12 PM
  3. Rough Idle
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-01-2010, 10:48 PM
  4. rough idle
    By stanggreg90 in forum General Tech Discussion
    Last Post: 05-22-2010, 11:37 PM
  5. rough idle
    By 02gtpalder in forum General Tech Discussion
    Last Post: 03-07-2010, 12:02 AM
