Thread: 2000 GTP Mystery
Results 1 to 6 of 6
  1. #1 2000 GTP Mystery
    Aug 2012
    michigan
    My grand prix has an engine stalling problem. Whenever the engine shakes, (shifting in/out of gear, bumps in the road) it wants to stall out. I have replaced the following already:
    Plugs/wires
    Fuel Pressure Reg
    Mass Air Flow
    Purge Solenoid
    Checked Vacuum Lines
    Replaced Injector O-rings/moved them around
    It isn't throwing any codes and it is much more of a common problem when at operating temperature. It has good compression and I have checked all of the fuses. Fuel pump seems to prime just fine when I start it. When it does die, it takes a few cranks before it restarts like it isn't getting any fuel. If I hover my foot on the gas a little bit I can keep it from dying on me.
    At this point I am thinking there may be some sort of bad ground in the block somewhere. When it is hot, I can grab a hold of the engine and shake it as hard as I can and feel it miss a little bit.
    Any help would be greatly appreciated...Thanks!!
  2. #2 Re: 2000 GTP Mystery
    Ohio
    Maybe the crank sensor.
  3. #3 Re: 2000 GTP Mystery
    clean the TB up real good.
    i bet you need a coupler too for the sc, and thats what you feel when grabbing the engine. you can take the sc belt of turn the pulley back and fourth, like snap it, if it clicks, you can feel it, and some times hear it. you need a new coupler.
    the main grounds are on your trans bell housing. right above the starter.
  4. #4 Re: 2000 GTP Mystery
    Aug 2012
    michigan
    Thanks guys for the suggestions. I will pull the TB tonight, check the grounds, and report back. If nothing improves then I will replace the crank sensor. It seems like a bit of a fiasco if I am not mistaken so I will save that for last.
  5. #5 Re: 2000 GTP Mystery
    Denver
    X2
    Had the trans rebuilt and I installed it myself ,missed one of the grounds and did the same thing
  6. #6 Re: 2000 GTP Mystery
    Didn't noob do the same thing when he replaced his engine in his car?
  1. Same mystery leak
    By 04gtpballin in forum General Tech Discussion
    Last Post: 03-18-2013, 10:44 PM
  2. Mystery Connection
    By dave380 in forum General Tech Discussion
    Last Post: 05-04-2012, 12:36 PM
  3. mystery sound??
    By spider4 in forum General Tech Discussion
    Last Post: 11-18-2011, 06:02 PM
  4. Oil line mystery
    By 62duoglide in forum General Tech Discussion
    Last Post: 04-12-2011, 05:14 PM
  5. Mystery problem with S/C
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2009, 01:08 AM
