Thread: Spark plug insulator cracks
Results 1 to 10 of 10
  1. #1 Spark plug insulator cracks
    Mar 2013
    AZ
    2004 GTP compG 80K miles.
    #3 spark plug has recurring issue with the insulator cracking. Replaced it twice now after about 1500 miles. Replaced all the plugs and no issue with them. What say ye experts?
  2. #2 Re: Spark plug insulator cracks
    St. Louis
    What brand/type of plugs are you installing? Are you using an actual spark plug socket or just a normal one? Anything in the area that may be hitting the plug?
  3. #3 Re: Spark plug insulator cracks
    Insulator on the exterior? That's plug socket and or angle when tightening.
  4. #4 Re: Spark plug insulator cracks
    Mar 2013
    AZ
    Insulator is not cracking on installation. Plugs are OEM. As I said, it takes awhile before the engine begins to miss. This plug is front and center on the engine, no issues with angle or access.
  5. #5 Re: Spark plug insulator cracks
    Mar 2013
    AZ
    Insulator is not cracking on installation. Plugs are OEM. As I said, it takes awhile before the engine begins to miss. This plug is front and center as you look at the engine from the front of the car, no issues with angle or access. Crack appears and runs from the terminal down through the ribs of the ceramic insulator.
  6. #6 Re: Spark plug insulator cracks
    And it's definately cracking and not say carbon tracking etc?
  7. #7 Re: Spark plug insulator cracks
    Mullet Member Wotgtp's Avatar
    Connecticut
    I'm going to suggest it's install error. Unless that part of the head is flexing so badly that it cracks the ceramic, but I'm sure you'd have far bigger problems then cracking plugs.
  8. #8 Re: Spark plug insulator cracks
    Connecticut
    Or you could just be buying a bad batch of plugs. When you need to change out the #3 plug, swap it out with another (like #1 or #5) and put the purchased replacement in that cylinders place. See what happens.
  9. #9 Re: Spark plug insulator cracks
    Mar 2013
    AZ
    The carbon tracking idea seems to ring the closest. Would this issue cause misfire?
  10. #10 Re: Spark plug insulator cracks
    It can. Usually it would be from a plug or wire. Sometimes a coil that isn't firing up to it's potential.
  1. Spark Plug Gap
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 10-14-2012, 09:57 AM
  2. which spark plug?
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2012, 07:39 PM
  3. what spark plug should I use?
    By jsaylor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2012, 11:44 PM
  4. Spark plug gap?
    By 91z in forum General Tech Discussion
    Last Post: 04-20-2011, 08:28 PM
  5. Spark Plug Help
    By STP5593 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 10:15 PM
