Thread: need help diagnosing engine damage
Results 1 to 18 of 18
  1. #1 need help diagnosing engine damage
    SE Level Member CountryBoy's Avatar
    Jan 2013
    Lima Ohio
    okay so my car is running rough and the boost gauge on my car is bouncing around 15"-20" of vacuum,the car is popping and banging like its running too rich and the car is shaking really bad at an idle. I already changed all the spark plugs and all the ignition coils. I'm thinking bad piston rings or chipped piston and or pistons. suggestions?? i know the pulley on the supercharger is a 3.4 instead of a 3.8 like it should be and i know i ran the car kinda hard so i know that its my own fault for not doing research before i got the car.
    Got Boost?
  2. #2 Re: need help diagnosing engine damage
    Did any of the plugs look funny like the ends missing or anything? If you need a motor I'll have one soon I'm going to part out my gtp.
  3. #3 Re: need help diagnosing engine damage
    If its running that bad, it must have thrown a code already.
    Either its a huge vacuum leak or the IGN module or some coil packs are bad.
  4. #4 Re: need help diagnosing engine damage
    Jan 2013
    Lima Ohio
    i already replaced all the plugs and ignition coils,it could be the IGN but i doubt it with the way its running,ds 2 of the plugs had the ends busted off them but the other 4 were in tact but very wet with gas/oil.
    Got Boost?
  5. #5 Re: need help diagnosing engine damage
    Nov 2011
    NY
  6. #6 Re: need help diagnosing engine damage
    2 busted plugs sounds like dead engine.
    Do a compression test.
  7. #7 Re: need help diagnosing engine damage
    Jan 2013
    Lima Ohio
    a compression test is on my list of things to try. any guesses on what exactly it could be?
    Got Boost?
  8. #8 Re: need help diagnosing engine damage
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    Replace the Ignition control module, bet that solves your issue, same prob as my ssei had.
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  9. #9 Re: need help diagnosing engine damage
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Quote Originally Posted by Nickell View Post
    He said two busted plugs, ain't that a dead giveaway that he chipped two pistons?
    Don't waste money before you do a compression test on any parts.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  10. #10 Re: need help diagnosing engine damage
    Jan 2013
    Lima Ohio
    I'll try that,but i have a sinking feeling that its something internal though
    Got Boost?
  11. #11 Re: need help diagnosing engine damage
    St. Louis
    With 2 broken plugs I'd be looking for a longblock, but that's just my .02. Do the comp. test and that will tell you for sure. Sounds like a chipped piston(s). The only other time I've seen a boost gauge bounce around was when there was a broken valve spring.
  12. #12 Re: need help diagnosing engine damage
    Would a chipped piston show on a compression test?
  13. #13 Re: need help diagnosing engine damage
    Jan 2013
    Lima Ohio
    I'm not sure if it would or not,but i put a scan tool on the car and it's throwing a code for cylinder 1 misfiring. so I dont really know what the deal is because neither of the busted plugs came out of cylinder 1
    Got Boost?
  14. #14 Re: need help diagnosing engine damage
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    on the cylinders with the bum plugs, the valves might be bent if peices of metal are flying through your engine,
    like others said do a comp test
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  15. #15 Re: need help diagnosing engine damage
    Jan 2013
    Lima Ohio
    thats the next thing I'm going to do,anyone know what the compression is supposed to be stock?
    Got Boost?
  16. #16 Re: need help diagnosing engine damage
    Jan 2013
    Edmonton, Alberta
    alldata says this for my 07
    The lowest reading should not be less than 70 percent of the highest reading.
    No cylinder reading should be less than 689 kPa (100 psi).
  17. #17 Re: need help diagnosing engine damage
    1. Tell us what the eff you drive
    2. Have you checked anything?
    3. Sounds like a bad O2 or map
  18. #18 Re: need help diagnosing engine damage
    Jan 2013
    Lima Ohio
    its a 1997 gtp 2 door,i replaced all the plugs and coils,i have all new wires for it,i scanned the car and the code is for a cylinder one misfire. compression test in my next step i think
    Got Boost?
  1. Need help diagnosing a few issues.
    By SlyBlackDragon in forum General Tech Discussion
    Last Post: 05-12-2012, 11:43 PM
  2. How could I tell if there has been engine damage?
    By SilvaMan61 in forum General Tech Discussion
    Last Post: 08-25-2010, 07:02 PM
  3. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  4. Need Help diagnosing tranny problem.
    By trbsht in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-05-2009, 12:33 PM
  5. diagnosing fuel leak
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 03:27 AM
