Thread: slite studder when cold start and rev
Results 1 to 5 of 5
  1. #1 slite studder when cold start and rev
    SE Level Member beattie's Avatar
    Mar 2012
    bryan,oh
    this is with autolite 104s if u notice in the video it only does it couple times then snappes out of this it happens everytime i first start my car when car is cold i do couple revs then its fine any suggestions they was gapped at .060 but it would do that start just at beging ov rev now there gaped at .050 and it will do it then go away
  2. #2 Re: slite studder when cold start and rev
    I couldnt notice a thing other than you romping on the gas on a cold motor.
    Try cleaning the thorttle body and the sensors and see if that helps. Other than that I couldn't even notice an issue.
  3. #3 Re: slite studder when cold start and rev
    Apr 2012
    Goderich, Ontario
    Its cold, let it warm up.
    -Paul Walker
  4. #4 Re: slite studder when cold start and rev
    Mar 2012
    bryan,oh
    i had a vacum leak fixed it now its fine and if u watch the video the first couple of revs it studders or missfires then is fine
  5. #5 Re: slite studder when cold start and rev
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    Mine used to do that, with new vac lines the issue went away
  1. squeak on cold start
    By blakgtp in forum General Tech Discussion
    Last Post: 09-21-2012, 06:02 PM
  2. e85 cold start
    By gtpsleeper in forum PCM Tuning
    Last Post: 01-03-2012, 12:35 PM
  3. 88 GP stalls when hot & won't start again until cold
    By MarkUSAF in forum General Tech Discussion
    Last Post: 08-02-2011, 04:38 AM
  4. ticking at cold start...
    By twol8uluz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2011, 10:01 AM
  5. cold start smoke
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 09:42 PM
