Thread: im looking for l67 pistons and rings
Results 1 to 9 of 9
  1. #1 im looking for l67 pistons and rings
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    im looking for a set of l67 pistons i dont know what size i will need until i send the block to a machine shop but i want to get a good pair of pistons rings that wont fail on me. does anyone hane any particular brands that they have used and that have worked well ?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: im looking for l67 pistons and rings
    Apr 2011
    Vassar, Mi
    I have 15-20k rather abusive miles on my Speed Pro pistons /Hastings rings @ +.030, no problems yet. It depends on how what your doing with it, silvolites are the cheapest but they look like cheap chinese garbage when you get them. I bought a set and sent them back as soon as I looked at them, I wouldn't recommend them for anything. Speed pros are pretty cheap at around $300, they look like a high quality precision piece plus they are ceramic coated but their still hypereutectic so they aren't any stronger than stock. Diamonds are the cheaper forged option. If your planning on modding past the basic bolt ons they would be good insurance but not completely necessary. Looking back I wish I had went with them in a 9.5cr when I built my engine. JE's are the good **** but their $800-$900.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  3. #3 Re: im looking for l67 pistons and rings
    Sep 2011
    palm harbor florida
    Federal-Mogul - Federal Mogul Hypereutectic Pistons #
    are these the pistons that you are talking about?
  4. #4 Re: im looking for l67 pistons and rings
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    those are speed pro, yes
    i wouldnt call those high quality pistons, but they are good quality piston
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  5. #5 Re: im looking for l67 pistons and rings
    Sep 2011
    palm harbor florida
    the next to best quality are the diamonds correct?
  6. #6 Re: im looking for l67 pistons and rings
    Jan 2013
    Edmonton, Alberta
    what are you planing for this car, tell us a story,
    its hard to recomend a piston if we dont know what your building (cam,pully ect.)
    diamond is a very good brand, but those speed pros will probly do what you want at half the price, look anthony's sig
    also keep in mind that if you buy a forged piston you need to run a little more cylinder wall clearence, with how dense forgings are they like to swell alot
    on a daily driver having some piston slap on every cold start might not be your best choice
  7. #7 Re: im looking for l67 pistons and rings
    Sep 2011
    palm harbor florida
    my car spun a rod bearing and im saving enougth money to rebuild the engine im planning on putting in a vs cam wiht all the neded valvetrain, headers. and possibly down the road do a 3.4 pulley wiht supporting mods
  8. #8 Re: im looking for l67 pistons and rings
    Sep 2011
    palm harbor florida
    anthony do you have a link where you bought your pistons and rigns?
  9. #9 Re: im looking for l67 pistons and rings
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    I am saving for my engine rebuild as well Doug. Although mine will be N/A, I do plan on supercharging down the road. I have been in contact with Diamond Racing about pistons, rings, and pins. They have assured me that thier "shelf" piston (which will take me up to 10:1 compression) can handle up to 20lbs. of boost. Here is the distributor they connected me with. Hope it helps!!
    Weber Power Products ATTN: Bill Woolsey
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  1. Does 1997 GTP SC have PCV o-rings ?
    By GTP in RTP in forum General Tech Discussion
    Last Post: 12-15-2011, 08:23 PM
  2. Hubcentric rings? used for wat?
    By keredwtf in forum Tires & Wheels
    Last Post: 07-14-2009, 02:57 PM
  3. Centering Rings on my new 18's
    By cboth686 in forum Tires & Wheels
    Last Post: 05-09-2009, 12:59 AM
