Thread: L67 Engine Swap and Cam Decisions.
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 80
  1. #1 L67 Engine Swap and Cam Decisions.
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Well ll be pulling my L67 on my gre gtp to put into my Na 40th sometime this year depending when i finish it all. I will be putting a L67 i picked up at the junk back into my gtp and selling itchanged all gaskets but won know if itturns over fine or has any issues till i crank it over. I have some questis when you have a spun bearing or a rod knock do you end up with some metal shavings on the oil pan or no?
    Also for anyone that lives in strict emision places like me in cali. What cam would you run that can pass smog without issue i am undecided between VS or XP?
    I use the car as a DD and street use and some track use but more of a street car. 91oct
    some pics of the engine i will be pulllig out of my gtp and the one going in it.
    The Engine Going into the GTP
  2. #2 Re: L67 Engine Swap and Cam Decisions.
    Spun bearings will send metal throughout the motor.
    Any cam can pass emissions. Its your choice of cat converter that will or won't let you pass.
  3. #3 Re: L67 Engine Swap and Cam Decisions.
    Buena Park Ca
    100% on this I have my xpz IS4 heads and supporting mods besides tranny and before I pull the trigger I want too n need to know if i can 100% pass with it before I drop the cash and a good Trans and small things needed as well as a tune.
  4. #4 Re: L67 Engine Swap and Cam Decisions.
    Indianapolis
    **** I wish my engine were that clean....
  5. #5 Re: L67 Engine Swap and Cam Decisions.
    Buena Park Ca
    Quote Originally Posted by TheNoob23 View Post
    A lot of elbow grease and prep time and work to make em look good but will stay looking good. Had it in the car for about 1 1/2 yrs still looks pretty good.
  6. #6 Re: L67 Engine Swap and Cam Decisions.
    Buena Park Ca
    Got it out.
  7. #7 Re: L67 Engine Swap and Cam Decisions.
    SE Level Member pontiac4lifesc's Avatar
    Mar 2012
    Winona, MN
    soooo i like what whats in the background i like your collection. black gtx hood for sale lol just kiddin, but seriously
  8. #8 Re: L67 Engine Swap and Cam Decisions.
    Buena Park Ca
    Quote Originally Posted by pontiac4lifesc View Post
    Haha thanks it's a habit. 4 gps and gonna be selling the grey one and a 40th soon.
    Also have a a couple of classics in the back shed there in the picture.
    67 mustang
    67 firebird 69 firebird
    Two 73 formula 400
    78 and 79 Trans am 403 block
    76 stingray
    and 67 camaro ss
    So there's a couple of cars lol
  9. #9 Re: L67 Engine Swap and Cam Decisions.
    Mar 2012
    Winona, MN
    lol thats awesome! im jealous
  10. #10 Re: L67 Engine Swap and Cam Decisions.
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    If you're gonna DD the car, go with the VS cam. All the power you need is below 6000 rpm. KR is nothing compared to high rpm's on a 3800. If you don't rev your XP to 6300 rpm or better, it probably won't make more power than the VS anyway. The key to a 200-300K mile 3800 is easy. Rev low, and eliminate KR. I'd rather have 6* of kr for 10 minutes than take a junkyard L67 to 6500 rpm for 10 seconds.
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  11. #11 Re: L67 Engine Swap and Cam Decisions.
    Buena Park Ca
    Quote Originally Posted by OrangeL67 View Post
    Well i have read good and bad between the both and many people comparing and picking them apart. I currently have a xpz cam IS4 heads and all supporting mods for that build till the new smog law started this year that change my mind if I can't pass with xpz which is what I am trying to find out.
    Also completely agree with you on the RPM and KR. I just want a fast dd enough to smoke srt8 without much issue at all.
    What about th S1x cam? I've heard that is in between the vs and xp cam.
  12. #12 Re: L67 Engine Swap and Cam Decisions.
    Nov 2009
    Michigan
    Quote Originally Posted by GTP89 View Post
    The s1x is inbetween the VS and XP in size, but the powerband is broader meaning you'll have to rev that cam more than the other two to get everything out of it. A stout VS setup would have no problems with an srt 8. Hell my setup ran a 13 flat with all sorts of kr due to a bad intercooler pump. I'm sure it would have performaed just as well as my xp set ups, only it didn't need to rev high to do it. I'm willing to bet there's a 100,000 mile life expectancy difference between a vs cam car and an xp/s1x car if both are tuned to take advantage of the powerband of the cam. For anyone who dd's thier car, I'd always recommend a vs. It's the best 3800 cam and it makes a ton of power everywhere in street revs. The trade-off in durability vs power on a scale of 1-10 is a 10 to 1.
  13. #13 Re: L67 Engine Swap and Cam Decisions.
    Buena Park Ca
    I was planning on using my xpz on my DD so as you can see I want the power lol just going from a XPZ build I had planned to a vs seems like such a huge gap. I mean would putting my IS4 heads on the VS be too much and gen v 3.0 pulley and N*, sfi balancer and so on I have pretty much all parts for my XPZ I just want to be able to have a reliable car of course and be crushin all the mustangs and srt8 out there with a good amount. And of course at the end be happy with it all.
  14. #14 Re: L67 Engine Swap and Cam Decisions.
    May 2008
    Schuyler, NE
    They have the sniffer test out in CA, right? If so, I would really reconsider doing any sort of a cam.
  15. #15 Re: L67 Engine Swap and Cam Decisions.
    Buena Park Ca
    Yup cali is one of the most strictest places for emissions.
    People have passed with cams on other cars like mustangs and camaros legally.
  16. #16 Re: L67 Engine Swap and Cam Decisions.
    May 2008
    Schuyler, NE
    You might want to send PRJ an email, since he has tuned Jonbob's car, who lives in CA. He would probably have some pretty valuable input.
  17. #17 Re: L67 Engine Swap and Cam Decisions.
    Buena Park Ca
    Very true I completely forgot about that. Any idea how I can get a hold of him?
  18. #18 Re: L67 Engine Swap and Cam Decisions.
    Bettendorf, IA
    how many GP's you have?
  19. #19 Re: L67 Engine Swap and Cam Decisions.
    Buena Park Ca
    Quote Originally Posted by pshojo View Post
    Two 40th sedan NA soon to be cammed and sc if all goes well.
    The grey GTP which I will be selling soon.
    And a GTX previous owner claims it is strokes so I will be tearing it apart to verify it is.
    So a total of 4 gps.
  20. #20 Re: L67 Engine Swap and Cam Decisions.
  1. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  2. Decisions decisions.. Needs honest opinions
    By GTPSHAWTY in forum Tires & Wheels
    Last Post: 01-20-2012, 08:34 AM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  5. Wich Cam? Decisions decisions.....
    By TDCRacing in forum General Tech Discussion
    Last Post: 12-07-2008, 11:39 PM
