Thread: Desperately need help!
Results 1 to 17 of 17
  1. #1 Re: Desperately need help!
    Wichita
    Does your car idle high? What are your RPMs at idle? @ 60? My guess is a massive vacuum leak.
  2. #2 Re: Desperately need help!
    Nov 2010
    Iowa
    Also, if im just cruising, when i let of the throttle the tach jumps up about 200 rpm before dropping as it should. I dont know if thats related buts thats something ive noticed for awhile
  3. #3 Re: Desperately need help!
    Quote Originally Posted by SCbuick010 View Post
    thats normal, the same thing happens if you tap the brakes in 4 th gear, with out letting off the gas at cruising speed. it the torque converter just unlocking.
  1. Headlight Issue...desperately need help!
    By Pontiac735 in forum General Tech Discussion
    Last Post: 11-26-2010, 09:14 PM
