i see you have an AF gauge... what is your LTFT? and yes with a 160 your prob not getting up to temp and running more fuel then needed. swap to a 180 at min and possibly the 195 for winter. even down here in FL i dont recommend a 160. i ran on on my Z when my trany was bad, as when the trany got to 185 it would slip. so the 160 gave me more time to keep it from slipping and also this is on the DOHC that had AL heads that cooled better then our iron heads.
to the OP. the Comp G has 3.29 gears vs the GTP's 2.92's... this will hurt HW mpg and may help in town. the gear swap helps low end acceleration.
