Thread: Advice on Street Building my GTP
Results 21 to 40 of 49
  1. #21 Re: Advice on Street Building my GTP
    You change the oil right?
    So you're partially concerned about the longevity of your engine right?
  2. #22 Re: Advice on Street Building my GTP
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    nope but i do have a dated receipt for an oil change the day before i bought it... so ya i care about my car if thats what your asking?
  3. #23 Re: Advice on Street Building my GTP
    Nov 2011
    NY
    Lol, I think some are trying to say... Do all the routine maintenance stuff and then some, maing sure the vehicle has a solid baseline to build from and then make a plan of where and how far you want to go with modding, HP, and $$$ wise... It's the best route and will serve you well in the long run. Without making sure the ar is solid mechanically prior to modding can be... Disappointing. Modding without a road map will cost you lots of $ and aggravation as you spend twice and do twice the work to arrive where you want to be.
    That said... After the maintenance, the fist thing I'd recommend is headers. Then tune, then upgrade intake, porting the S/C and TB, retune, then drop pulleys while actively scanning for knock. Remember the golden rule...
    Fast/Reliable/Cheap
    You can only have two of these, be careful with your choice!
    Regards
  4. #24 Re: Advice on Street Building my GTP
    Never Never Land
    Always worry about knock. These cars knock stock. Pulleying down causes more knock. The smaller the pulley the more detrimental it can be to your motor. Get a scangauge to monitor knock before you end up on the side of the road waiting for a tow truck.
  5. #25 Re: Advice on Street Building my GTP
    Feb 2013
    Illinois
    noted
  6. #26 Re: Advice on Street Building my GTP
    Here is the short list of power more:
    Intercooler and pulley.
    Cam and pulley.
    Heads and pulley.
    Or any combination of the above.
    Or a turbo conversion.
    They all require a significant investment, and will test the integrity of your stock transmission. You can easily make it last, but if you beat on it at all, which I would assume you would, given you're interested in more power in the first place, it simply won't last.
    Figure that into your budget in the course of a couple years.
    Unless you plan on making some power, blowing something up, and bailing. Don't feel bad about doing that either, many have done that too.
  7. #27 Re: Advice on Street Building my GTP
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    ZZP canned tunes suck. Period. There was a scenario where someone had MORE knock with a ZZP tune than they did a stock tune.
    I had more knock on zzp 1.0 then I did on stock tune. I had to get 1.9's to run a 3.4
  8. #28 Re: Advice on Street Building my GTP
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Next mod IMO should be a set of 1.9's rockers. Fairly cheap upgrade and not too deep into the motor. Cam install is much more involved.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  9. #29 Re: Advice on Street Building my GTP
    They're $280 from ZZP, $100-180 used. Helps with the top end, but they're not worth the investment. Had 1.9 rollers, not worth it IMO.
    Given the age of your factory springs, you'd want new L76 springs or at the very least new factory replacement springs.
  10. #30 Re: Advice on Street Building my GTP
    Apr 2011
    Columbus, OH
    $50 for a set of L76 springs and $150 for 1.9's (have a set I could sell you) and will for sure help with an KR if it's present. So for $200 and a little time and effort is totally worth it. Gives you more power on the top end where as a cam will help more throughout the entire powerband.
  11. #31 Re: Advice on Street Building my GTP
    Never Never Land
    Baaaaaaammmm.
  12. #32 Re: Advice on Street Building my GTP
    Feb 2013
    Illinois
    thanks greg maybe we can work out a trade for that plog lol
  13. #33 Re: Advice on Street Building my GTP
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    i have 0 knock on my zzp canned tune
    i have:
    home made intake
    ported sc inlet/outlet
    3.25 pulley
    3 angle valve job
    heads milled .005"
    casting ground out of exhaust ports
    cometic .052" headgaskets
    zzp nic cam
    sd headers
    slp loudmouth catback
    no cats
    no egr
    no evap
    must have a retarded car....
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  14. #34 Re: Advice on Street Building my GTP
    Feb 2013
    Illinois
    lol guess so
  15. #35 Re: Advice on Street Building my GTP
    May 2008
    Schuyler, NE
    Care to back up your claim?
    What canned tunes don't suck?
  16. #36 Re: Advice on Street Building my GTP
    Never Never Land
    And yes canned tunes suck.
  17. #37 Re: Advice on Street Building my GTP
    Feb 2013
    Illinois
    i would imagine that no matter what a custom tune would be better.. hence the word CUSTOM
  18. #38 Re: Advice on Street Building my GTP
    Never Never Land
    Yes. Get a quality custom tune, if you want to have the safest and most powerful tune you can that is.
  19. #39 Re: Advice on Street Building my GTP
    Feb 2013
    Illinois
    sounds good to me
  20. #40 Re: Advice on Street Building my GTP
    Sep 2011
    Copperas Cove, TEXAS
    Thought I would suggest a few things, unless the previous owner did these, might want to knock these off the list.
    SC oil change
    PCV
    Check vacuum hoses
    Check Belt (both)
    Trans Pan Drop with new filter
    Check Coolant Elbow/s
    Coolant flush
    Plugs and Wires
    Fuel Filter
    Clean MAF
    Clean Throttle Body
    Try to keep up on these so any new mods will last. Oh and start a Members ride thread to post pics of your Gold Ride.
  1. Building My Own Intake
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 02-04-2012, 11:47 AM
  2. Building my bro a PC.
    By Odi in forum Off Topic Discussion
    Last Post: 01-07-2012, 04:41 AM
  3. Help with building a sub box
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 05-27-2010, 11:35 AM
  4. Building a 93 pro street grand prix n have a chassis ?
    By lukeeep in forum Brakes/Suspension/Chassis
    Last Post: 03-28-2009, 08:01 PM
  5. Building Cold Air
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 09:33 PM
