ZZP tunes are fine. Anyone that tells you different has probably never seen how similar they are to WBS, DHP, 3800performance, Intense, Overkill, etc...
Which brings about the point, they're a waste of money.
Even street tunes can be pointless.
The only things you'll ever notice are the transmission settings.
Stock tune should be fine with a plog/dp and 3.5 as far as fuel goes. They tend to run somewhat rich already.
But knowing if the car has KR is something you'll want to know about. A tune will just help with a few small aspects as of right now because those mods arent very serious. I'd suggest not buying a ZZP tune and going with a different vendor or a custom tune.
Mechguy had a reptile PCM which caused more KR than his stock PCM.
He finally gave up and pullied up IIRC.
Quote Originally Posted by Dakoda View Post
Hi im just looking for good routes to go as far as gaining more power. This is going to be for a DD so nothing to crazy. Right now all thats done is a zzp downpipe and plog with a 3.5 pulley...
You're not going to get much better performance without dropping a bunch of cash.
Just enjoy your car as is and don't worry about.
This is all assuming you've already monitored for KR under numerous conditions for an extended period of time.
