Thread: Grandprix Chugging after startup...dies
Results 1 to 16 of 16
  1. #1 Grandprix Chugging after startup...dies
    SE Level Member ajc549FF's Avatar
    Lake Zurich, IL
    Hey all.
    So my 98 GTP was running perfectly fine this morning while driving home. Two hours later I used the remote started the car and it sounded like it had a cam so I cut it and took a look under the hood just to make sure everything was as it should be.
    I started it back up a minute later and it ran fine so I got in the car and reversed it out of the driveway and the gtp began really chugging, i put it in drive and tried to get it back in the driveway and it wouldn't even move then began to move an inch then the engine wanted to die (I was giving a good amount of throttle) Got it back in the drive and tried again, same thing happened.
    What do you think? Tune up last year along with new fuel filter last year.
    Thanks.
    98GTP 3.5in tips, headers, fenderwell intake, 180tstat...3.5pulley?
    1984 Four Winns (Boat) 190 Horizon 19ft open bow...new 350 soon! and Thru Hull exhaust!
    03-07 Duramax Diesel next summer after paramedic is finally over!
  2. #2 Re: Grandprix Chugging after startup...dies
    St. Louis
    Is the CEL on? Try disconnecting the MAF and see if it runs better. It will want to idle badly for a bit so keep some throttle on it and it should stay running. If this helps then you could have a bad MAF. Oh, and don't drive around w/o the MAF connected more than you have to, and def. stay out of boost.
  3. #3 Re: Grandprix Chugging after startup...dies
    Pennsylvania
    I'd look into the MAF. Maybe a clog in the air intake somewhere. Or a massive vacuum leak.
  4. #4 Re: Grandprix Chugging after startup...dies
    Lake Zurich, IL
    No the CEL is not on. I unplugged the MAF but no change...
  5. #5 Re: Grandprix Chugging after startup...dies
    Pennsylvania
    No change after unplugging MAF? Jolly good. Sounds like the MAF isn't working.
  6. #6 Re: Grandprix Chugging after startup...dies
    Lake Zurich, IL
    Thats what I'm thinking...I went outside just a half hour ago to start it up with wishful thinking it was fine for about 2 minutes then started acting up again....but I saw the Check engine light on and got my scanner...by that time the engine choked out and I attached the scanner and nothing on the scan and I realized the CEL was off! :/
  7. #7 Re: Grandprix Chugging after startup...dies
    Pennsylvania
    It should still have codes stored.
  8. #8 Re: Grandprix Chugging after startup...dies
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    it almost sounds like it is not firing on all the cylinders, like a bad coil pack almost.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  9. #9 Re: Grandprix Chugging after startup...dies
    Pennsylvania
    Quote Originally Posted by BlackGT97 View Post
    That probably wouldn't cause stalling, just breakdancing.
  10. #10 Re: Grandprix Chugging after startup...dies
    St. Louis
    Could be a failing ICM. You need to see if you can get those codes read. Would take some of the guesswork out of it.
  11. #11 Re: Grandprix Chugging after startup...dies
    Lake Zurich, IL
    Yeah im going to try using a different reader tomorrow hopefully if i can get my hands on one...maybe could it be the CPS? Literally it starts just fine then after like a half a minute it starts to chug and loap like a cam then stalls out.
  12. #12 Re: Grandprix Chugging after startup...dies
    Omaha, NE
    Crank Position Sensor.
    Or tune. I made a stock GTP lope hard at idle once via tune.
  13. #13 Re: Grandprix Chugging after startup...dies
    Lake Zurich, IL
    Is there a relearn process for the car with replacing the cps?
  14. #14 Re: Grandprix Chugging after startup...dies
    Lake Zurich, IL
    SO update here!
    Messed with it again today I unplugged every sensor separately starting the car with each individual unplugged and no change in how the car was acting. BUT we plugged everything back in and started it up, it wanted to die like it has been, we kept throttle on it for about 20-25 seconds and it got over like this hump and it ran 100% ok! Took it for a drive and everything...we turned it off and let the car cool down started it back up and it started chugging once more so we kept throttle on it for about 20 seconds and it started to run just fine again no issues.
    Any ideas?
  15. #15 Re: Grandprix Chugging after startup...dies
    Pennsylvania
    What happened to scanning it? I still say your maf is borked.
  16. #16 Re: Grandprix Chugging after startup...dies
    check the wires to the maf plug, if you see bare wire thats not good.
    checked for vac leaks yet?
  1. Chugging?
    By ljmonnin12 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2012, 02:53 PM
  2. car occassionally dies on startup
    By FX4 Level II in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2012, 10:37 AM
  3. Chugging
    By mlasnoski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2011, 08:02 PM
  4. chugging
    By davisg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2011, 06:01 AM
  5. 1988 grandprix tranny to 1993 grandprix
    By avaitors in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 09-14-2009, 03:34 AM
