Thread: L67 "Inspection" Advice
Results 1 to 20 of 51
Threaded View
  1. #1 L67 "Inspection" Advice
    SE Level Member Quaraxkad's Avatar
    Apr 2012
    Port Orange
    I've got an L67 (with 4T65E-HD) from a junkyard, I took it out of a 2000 Pontiac Grand Prix. Odometer showed just over 210K miles, the body was a decent shape, it wasn't in an accident so I'm suspecting it had engine or transmission issues that led to its residence in the junkyard. I won't be able to get it installed in my car to test it within the 30 day warranty period. So I want to tear it down a bit and get a better look at the internals. I'll take off the S/C, the heads, probably the oil pan. I'd rather not do a *full* rebuild, so what are some problem areas that I should pay special attention to here (aside from the obvious, cracked pistons, bent rods, etc)?
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  3. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
