Thread: 2002 throttlebody on a 97 supercharger
Results 1 to 9 of 9
  1. #1 2002 throttlebody on a 97 supercharger
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    can i do this ?
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  2. #2 Re: 2002 throttlebody on a 97 supercharger
    not sure if your maf fits the hole in the TB right.
    another thread a guy was using a 98 maf in a 99 TB iirc, and m still waiting to hear back is it was sealing tight or not. or causing him a vac leak.
    you need to use your maf. the 2002 wont work. pretty sure it wont even plug into your harness.
  3. #3 Re: 2002 throttlebody on a 97 supercharger
    Arizona
    IF you di it you will have a p0171 and the MAF wont go into the throttle body two diffrent models after the 99' year better of going northstar or something and getting tuned for it.
  4. #4 Re: 2002 throttlebody on a 97 supercharger
    If you use your 02 tb on your 02 car the sc will bolt up fine and you'll just have to redo some vacuum lines
  5. #5 Re: 2002 throttlebody on a 97 supercharger
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    yes u can do a 02 on a 97 but the maf are diff from a 97 to a 02 the 97 is smaller then the 02 and it would need to be retuned for the different maf
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  6. #6 Re: 2002 throttlebody on a 97 supercharger
    Sep 2012
    bridgeport,NY
    i will be using the 02 maf sensor there car right now has a 97 tb and maf on it thats causing a p0171 hence why i need a 02 tb and maf
  7. #7 Re: 2002 throttlebody on a 97 supercharger
    Erik, you sure can.
    As well, it won't automatically set any codes. It might, however when you swap it on, you should put the 99-03 maf table into the tune and then you'd have the right table for the maf in the TB. Flow is slightly different from 97-98 to 99-03. I have tossed an 02 motor into a 98 w/o changing the table and never had an issue. PCM sucked up the slack for me.
  8. #8 Re: 2002 throttlebody on a 97 supercharger
    Jersey
    I have done this without touching the maf table as well, worked well
  9. #9 Re: 2002 throttlebody on a 97 supercharger
    Sep 2012
    bridgeport,NY
    its has the table for an 02 in it. ive been chasing a p0171 for a while and never knew the tb was the issue blue cleared that up for me. thank you everyone for the help now the hunt is on for a tb to go in
  1. 02 l67 throttlebody
    By Erik Adam Rodriguez in forum Wanted To Buy - Parts
    Last Post: 02-13-2013, 05:21 PM
  2. ZZP throttlebody
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2009, 10:20 PM
