Thread: Please help
Results 1 to 16 of 16
  1. #1 Please help
    Mar 2012
    RIVERDALE IL
    GTP+007.JPG i have a 97 pontiac grandprix gtp i cant find out where do that plug go my uncle did a lim job on my car today but the car would only run if we hold our foot on the gas pedal we cant figure out where do that plug go can someone plase help
  2. #2 Re: Please help
    Intake air temp sensor or coolant temp sensor
  3. #3 Re: Please help
    if its not for the iat sensor in the intake tube.
    it could be the temp sensor under the t stat housing.
  4. #4 Re: Please help
    Yup. temp sensor under the thermostat on the LIM.
    As for the running with only the foot on the gas, if the plug doesnt fix it you may have a big vacuum leak.
  5. #5 Re: Please help
    Mar 2012
    RIVERDALE IL
    do anyone have a picture where its located at ?
  6. #6 Re: Please help
    Under the thermostat like we said.
    But here is a picture.
  7. #7 Re: Please help
    yeah lim job= a vac leak. check all the T's, and the fat vac line off the TB. it seems every one who does a lim job breaks a vac line or two. its common.
    i re did all my vac lines for about 5 bucks, and that included 2 new T's, i used plastic T's its all thats out there.
  8. #8 Re: Please help
    (Shaking head at Dan, IAT is only a two wire.....)
  9. #9 Re: Please help
    I'm on my phone couldnt really see it
  10. #10 Re: Please help
    I could see that one your phone from here!
  11. #11 Re: Please help
    I just saw a little plug and figured those are the 2 most overlooked ones
  12. #12 Re: Please help
    i saw the plug to the main harness on top of the engine on the open pig tail. i knew that was the temp sensor plug right away.
  13. #13 Re: Please help
    Mar 2012
    RIVERDALE IL
    ok i found the temp sensor and plug it up but it didnt fix the problem my car would only start if my foot is on the gas pedal but when i unplug my mass air flow sensor the car would stay running but it act like im constantly stomping the gas pedal to the floor
  14. #14 Re: Please help
    Now you need to fix the vacuum leak. Use some tb cleaner to find the leak.
  15. #15 Re: Please help
    listen to BIll, hes right 102% of the time lol
  16. #16 Re: Please help
    tennessee
    indubitably^^^^^
