Thread: RPM jumping up in down
Results 1 to 9 of 9
  1. #1 RPM jumping up in down
    Aug 2012
    SE Wisconsin
    Hey guys, I have encountered a small annoyance/problem with my new 2003 GTP 108k miles... I noticed that the idle isn't perfect, it moves about 100 or so RPM consistantly and then while driving in 3rd and 4th/overdrive I get shuddering. The car seems to lurch then fall off then lurch. Now this isn't dramatic, just minor, but the rpm can jump 200-300 RPM quick while accelerating lightly. WOT is no prob, nor is accelerating in lower gears. Could this be the MAF sensor? My MPG's are still good. I took out the MAF and sprayed it with MAF cleaner, but still does the same thing. I tried to test ohms, but my voltmeter isnt high enough grade to tell if the voltmeter is lagging or the signal is actually jumping. Just want to get your opinions before buying a $100 part. Wish I had a known good one I could throw in as a test. Also need to pray it's not the LIM acting up, but could it be?
    Thanks in advance
  2. #2 Re: RPM jumping up in down
    What you are describing is typically tune up related. Plugs, wires, cleaning maf and cleaning TB are the usual fixes. Especially if you don't know when this was last done.
  3. #3 Re: RPM jumping up in down
    Aug 2012
    SE Wisconsin
    Yah I thought so too. However there are reciepts for a nice set of pulstar plugs only a few thousand miles ago and i believe he said he did wires at the same time. I cleaned the TB and the MAF already with hefty doses of MAF cleaner.
    Put normal plugs in it. Ac delco 41-101.
  5. #5 Re: RPM jumping up in down
    ^^^ I agree. Our cars don't like Bosch plugs and I haven't heard of anyone using pulstars
  6. #6 Re: RPM jumping up in down
    Aug 2012
    SE Wisconsin
    Alright thanks guys, I'll check to see exactly what the plugs were that went in. Seems odd though that this hesitation and rpm jumping only comes in under a load while in later gears though.
    Edit: Forgot to mention, there are no CEL's whatsoever. May be comletely unrelated, but my TCS also doesn't seem to be functioning. Light isn't on for trac off, and the button doesn't do anything. was able to continuously spin tires after start up (warm of course ;p) and then pushed the button and still non-stop tire spin. If this is unrelated I'll make a new thread for that issue.
  7. #7 Re: RPM jumping up in down
    Actually ...it's not odd at all.
    Lower rpms, more load, more work on ignition system. It's common in our platform. Trust me.. one night WOTGTP thought he had a trans issue..we fixed it with a set of plugs.
    Of course..weeks later..he did have a real trans issue.
  8. #8 Re: RPM jumping up in down
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    lol i though i had a trans issue had just put new plugs in it already had newer wires turned out to be a bad wire right at the plug burnt threw... i had LTW wires so i got a new set and bam all better
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  9. #9 Re: RPM jumping up in down
    Aug 2012
    SE Wisconsin
    For those who contributed in the past... just an update:
    Plugs changed: No difference
    Wires Checked
    Engine scanned
    Everything was fine.
    So I changed the trans fluid and filter along with adding a bottle of lucas.
    This is what my fluid came out looking like! Dont worry I think most of the black specs were in the container before the fluid got there.
    Result: A whole new car. Smooth shifting and none of the RPM changes I was seeing before. It's been about a week now since I did it... Maybe 100 miles mixed driving.
    May just be a bandaid, or maybe I'll get some good life out of what's left in the transmission. Guess it depends whether it's the clutches or something in the valve body.
    So thanks for all the input. Clearly it's going to be a trans rebuild in my hopefully not to near future.
  1. PLEASE HELP!!!! Tachometer keeps jumping!!!!!!
    By Donald Mosley in forum General Grand Prix Discussion
    Last Post: 12-18-2011, 11:29 PM
  2. Just not jumping like it should!
    By BigmikesSilverBullet in forum General Tech Discussion
    Last Post: 04-29-2010, 12:52 AM
  3. jumping rpms
    By 99GP3800GT in forum General Tech Discussion
    Last Post: 03-17-2010, 12:49 AM
  4. Gas gauge jumping
    By bxfl in forum General Tech Discussion
    Last Post: 03-15-2010, 01:44 PM
  5. Gears jumping around?
    By WhiteGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-18-2008, 09:10 PM
