Thread: Bad Supercharger
Results 1 to 12 of 12
  1. #1 Bad Supercharger
    Dec 2012
    I have a 1999 grand prix gtp, and ive been told that there's a bearing going bad in the supercharger snout and i was wondering if it would be cheaper to rebuild it or just to buy a new/used one off of ebay
    Dec 2010
    DMV
    You've been told? Does it sound like rocks rumbling around In the snout?
  3. #3 Re: Bad Supercharger
    Jan 2012
    Philadelphia
    It is probably your coupler, cheap and easy fix
    Eaton - EATON Replacement Coupler #ETN-30858
  4. #4 Re: Bad Supercharger
    Dec 2012
    Yeah
  5. #5 Re: Bad Supercharger
    Dec 2012
    How would i find out whether it is or not?
  6. #6 Re: Bad Supercharger
    Omaha, NE
    More than likely its the coupler. Take it apart and see if the holes are oblong, they should be a perfect circle.
  7. #7 Re: Bad Supercharger
    Max Cook
    Guest
    if it isnt the coupler and is one of the bearings consider looking at upgrading to a GenV M90 instead of buying another Gen3. Thats what I did when my bearings went out in mine. Good excuse to upgrade. This is asuming you have mods or want more performance anyway.
  8. #8 Re: Bad Supercharger
    GTP Level Member buickman104's Avatar
    NYC
    Easiest way to confirm a bad coupler is to take the belt of the supercharger and with your hand check for play.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  9. #9 Re: Bad Supercharger
    Dec 2012
    Is it bad/dangerous for me to drive my car if the coupler/bearing is going bad?
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Not if you disconnect the supercharger belt. But its an easy fix so why not do it?
  11. #11 Re: Bad Supercharger
    Quote Originally Posted by DustinBjug View Post
    If the bearings are bad, its already boned.
    If its just the coupler, you can still drive it, wont do anything bad unless in a freak case the coupler breaks apart.
  12. #12 Re: Bad Supercharger
    Nov 2011
    NY
    Been told by whom? What's their experience with the 3800 & s/c's? Like everyone has said, it's probably just the coupler, I had the sound too when I got my GTP.
    Its a $30 fix... To change the snout oil and the coupler. Go for it, will take about an hour to do. Worst thing is you wasted $30 and an hour of your time, best thing is you saved big $$$
  1. Supercharger
    By dewman21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-12-2012, 08:42 AM
  2. Supercharger bearings shot!:o no more supercharger?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2011, 02:27 PM
  3. Supercharger coupling OR Supercharger belt tensioner?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 07-23-2010, 11:56 AM
  4. Will a 2001 Bonneville supercharger work on a 97 gtp?supercharger swap
    By Bunique7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2010, 08:39 PM
  5. supercharger
    By sUpErClEaNbLaCkMaChInE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 01:50 PM
