Thread: Rough idle only when in drive
Results 1 to 10 of 10
  1. #1 Re: Rough idle only when in drive
    St. Louis
    Did you check the vacuum "T" under the S/C? That's a common place for a leak. Also, maybe the EGR pipe?
  2. #2 Re: Rough idle only when in drive
    Mar 2012
    East TN
    Quote Originally Posted by FordMan77 View Post
    Yeah,the lines around that area look brand new. I sprayed it just to be sure, still did nothing. I haven't really checked the EGR. Is there anything in particular to look for? The 2 hoses from the EGR look fine from what I could see. Should I pull it off and give it a look?
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. Rough idle
    By GTP2188 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2012, 03:12 PM
  3. Rough Idle
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-01-2010, 10:48 PM
  4. rough idle 02 gtp
    By 02gtpalder in forum General Tech Discussion
    Last Post: 03-06-2010, 01:16 PM
  5. 91 GP rough idle
    By Juanmiguel in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-04-2010, 11:07 PM
