Thread: Car won't shift after sitting overnight
Results 1 to 8 of 8
  1. #1 Car won't shift after sitting overnight
    Apr 2011
    Gainesville, FL
    I have a 97 Grand Prix GTP with 182,000 miles. After sitting overnight, the car will not shift out of first until it runs for about 2 minutes. After that, it shift fine. If the car sits during the day for many hours and then I drive it, it shift fine. I am not getting an SES light either. Any recommendations?
  2. #2 Re: Car won't shift after sitting overnight
    Get the car scanned still. Most trans codes dont set the SES off.
    You might have a solenoid sticking.
  3. #3 Re: Car won't shift after sitting overnight
    Apr 2011
    Gainesville, FL
    I scanned it and don't get any codes
  4. #4 Re: Car won't shift after sitting overnight
    Jan 1970
    Maquoketa, Iowa
    Could be the checkball?
  5. #5 Re: Car won't shift after sitting overnight
    Apr 2011
    Gainesville, FL
    what is the checkball?
  6. #6 Re: Car won't shift after sitting overnight
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Check the fluid level ?
    1997 Red GTP 182000 miles stock
  7. #7 Re: Car won't shift after sitting overnight
    Apr 2011
    Gainesville, FL
    Fluid is good.
  8. #8 Re: Car won't shift after sitting overnight
    Could be a multitude of things. Most likely as mentioned there's something not going well until it's warmed up a bit. How often do you typically service the transmission?
  1. So when your sitting around at home...
    Last Post: 12-28-2012, 10:11 PM
  2. battery dies overnight please help
    By orangecreme in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2012, 11:32 PM
  3. Transmission won't shift into drive after sitting overnight
    By Toadster in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 06-09-2011, 05:52 PM
  4. How she's sitting right now!
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 03-10-2010, 04:37 AM
  5. So im sitting here.. With a visa....
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 09-18-2009, 09:03 PM
