Thread: Dad gave us the OK, time to build up the 95 3800
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #1 Re: Dad gave us the OK, time to build up the 95 3800
    Just seeing this thread. Being a former Bonne guy, I have the pinouts at the firewall mapped from 95 to 97, 98 and 99 if you wanted to pick up the harness, pcm and make yourself a couple of pin changes to have it work off the best pcm possible.
    I'm assuming you are starting with an NA car. A 95 SC Bonne is a Series I motor, NA was Series II though.
    Trans: The 4T65E benefit is that the pump was intended for higher rpm, the 4T60's had issues based on the pumps cavitating and starving the trans for fluid. Also many more of these have been built up than the 4T60. HD diff is considerably bigger as well IIRC. I would suggest going 98 or 99 as the TCC lockup etc is the better of the possibles and you could drop a 4T65E into it.
    Suspension: Nice part of a Bonne is you can put in a set of drag bags for ~$80 and nearly kill all the weight transfer. This will make you faster off the line. You could also stuf a set of air struts in the back (SSEi or any of the bunch with autoleveling) and use the monroe airline kit (I think it's AK29) to help with more of the weight transfer by pumping up the struts as well. Neither of these items compromise ride quality. You could also swap up to the SSEi or PA sways/springs for slightly better cornering on the ocean with th boat.
    Braking: if you want better braking, read up on 95NASTA's postings about his conversion to W body struts/knuckles and F body brakes. Bonne brakes are horrible stock.
    Intercooler pumps and fuses/relays: Kinda cool depending on what you do, but you can easily add in relays and fuses to the center under the hood and have it look stock.
    Motor movement: I can't suggest this highly enough and depending on what brand of headers you use, you likely will have to mod the mount anyhow for clearance. I removed the shock, cut the ear off and welded it horizontally. Used hockey pucks cut down as a spacer and a serious grade 8 bolt. (Password for all my PB is Boosted)
    Motor Mount Photos by billboost37 | Photobucket
    Exhaust: I went SLP headers into 3", with 3" cutout, then 3" high flow cat, 3" pipe from there straight back until the exhaust curves around the fuel tank. I left that piece 2.5" (stock) into a stock SSEi muffler with dual outlets. You shouldn't have any backpressure issues with that type of setup. And it gives you that initial throttle room in the 3" pipe. I didn't get the chance to use the cutout at the track.
    If you go electric WP, consider adding the 2000+ Bonne power steering pump bracket. It moves the pump back about an inch or so and belt clearance to the TA mount is much better. (you'll need to grind that down as well)
    Mezier Photos by billboost37 | Photobucket
    Oil pan: When you get to pulling the motor. I highly recommend the 2000+ aluminum oil pan (Bonne), pick up tube and oil filter adapter. No more oil on the subframe and a structural pan that iwll allow you to jack the motor easily w/o pan issues when you change out the TA mount.
    Intake: Depending on how you go.. it's super easy to spin you pcm sidewasy, pull the canister and retain it then use a nice big fwi
    Want to go full IC with Gen V and N* TB. No worries about it hitting the hood. You are perfectly fine.
    Thinking about upgrading your radiator from that thin poor excuse to a real one? Call RadiatorBarn.com and see if the 93 El Dorado with 4.3 they sell still has the 1 5/8" core. It's a direct swap in. Oh yeah!
    Shall I keep going?
  2. #2 Re: Dad gave us the OK, time to build up the 95 3800
    Donating Users 02GTINFERNO's Avatar
    Dec 2012
    Buffalo, NY
    If you want to please haha. My dad asked me if i had any prices yet so this will give me a food start to see what i can get and from where.
  3. #3 Re: Dad gave us the OK, time to build up the 95 3800
    Tell him 10K is the high end and 5K may be the low end.
    Ok, go to photobucket and login to BillBoost37 with a password of Boosted . When you see something you want more info on like heated seats, map light homelink, fog light switch relocation, extra power outlets, just holler.
  4. #4 Re: Dad gave us the OK, time to build up the 95 3800
    Or maybe I'll tease you further.
    Recognize it?
    The day Bertha went in
    Should have been a standard option
    Hmmm which is the original?
    Sunroof switch
    Eat your heart out, you can change the trunk lid and tail lights on your car. Can you imagine how the GP guys would kill for this kinda mod?
  5. #5 Re: Dad gave us the OK, time to build up the 95 3800
    Jul 2012
    Chicago
    Basically.. Bonnes rock.
    -Carl
  6. #6 Re: Dad gave us the OK, time to build up the 95 3800
    Did I mention the summer that 2003 SSEi and I hung out together? Yeah.. I might have suggested things were possible, then he took it to a whole new level.
  1. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  2. Time for more POWAAA! (GEN V Build)
    By AmericanSoldier in forum General Tech Discussion
    Last Post: 11-03-2011, 08:07 PM
  3. if you could build your dream 3800 motor what would you use
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2010, 12:30 PM
  4. Gave Her The Works, Spring Time
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 04-05-2010, 11:49 PM
  5. well I am starting a new audio build. This time it is sq.
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2008, 06:08 PM
