Thread: powertrain vibration
Results 1 to 9 of 9
  1. #1 powertrain vibration
    Jul 2008
    hiawatha iowa
    anybody have an idea what might cause a vibration only when acclerating.
    im thinking cv shaft play or engine mounts.
  2. #2 Re: powertrain vibration
    Barksdale AFB, LA
    CV shaft, most likely the tripot joints.
    2009 Subaru Impreza WRX STI
  3. #3 Re: powertrain vibration
    your car lowered? if so, you need engine mount spacers or shorter axles.
  4. #4 Re: powertrain vibration
    Jul 2008
    hiawatha iowa
    car is not lowered.
  5. #5 Re: powertrain vibration
    then it's 95% likely to still be your shafts, the inner joints are probably loose, atleast one of them
  6. #6 Re: powertrain vibration
  7. #7 Re: powertrain vibration
    Odessa, MO
    Yep, CV shaft, just relaced one on a friend's GTP for the exact same reason.
  8. #8 Re: powertrain vibration
    Jul 2008
    hiawatha iowa
    cv shaft right inner was bad.
    thanks everybody for your help.
  9. #9 Re: powertrain vibration
    Barksdale AFB, LA
    Quote Originally Posted by 00pontiac1971 View Post
    Exact same thing that was wrong with mine. Passenger side tripot (inner) joint was all chewed up. Dealer had "fixed" a leaking boot under warranty, and here's what I think of their fix.
  1. Terrible Vibration.
    By 99LuminaLSC in forum Brakes/Suspension/Chassis
    Last Post: 12-31-2008, 10:46 AM
  2. 01 GT Vibration in Front Right End
    By sweard2003 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2008, 08:57 AM
  3. 01 GP gt bad vibration when cornering right
    By 01RedfireGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-16-2008, 05:28 PM
  4. Is it worth it Powertrain Swap
    By WindsorGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-19-2008, 08:59 PM
  5. Please help with Vibration Problem
    By John_Shughart in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2008, 09:57 PM
